Old 12-19-2017, 04:49 PM   #1
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
November 2017 recall?
Hi, I just got this in the mail.
It's for my other Toyota (2007 Avensis wagon) and it's about a recall for the passenger side airbag. In the letter it says that "due to manufacturing fault, if the unit stays inactive for a while, traces of humidity may be found inside, which would be dangerous for our customers, if the airbag deployed" Blah blah blah, that's really serious.
Have you had any recalls like this in the US? What's your experience? It's the second recall for the Avensis. We had another 2 I think for the Yaris. One was the sticky driver's window switch, and another one which I dont remember what it was about.
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 12-19-2017, 06:13 PM   #2
xdarkxfirex
Drives: 2015 yaris le
We had this in canada. It was for the airbag inflator. I think the US had the same recall
xdarkxfirex is offline   Reply With Quote
Old 12-19-2017, 06:27 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Yes, the Takata airbags are used in a variety of vehicles, not just Toyota models. I had mine replaced at no cost.
On Instagram
On Wheelwell
Old 12-19-2017, 09:53 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yup, my 08 goes in on 28 December for the airbag replacement as well as steering column spiral cable and seat rail. My 06 goes in in June for a total of 5 recalls. The 06 would go in sooner but I asked the dealer to wait until June as it's in storage for the winter.
Old 12-20-2017, 07:49 AM   #5
komichal
My Yaris 2007 went for driver side airbag change last year and I was told that once the passenger airbags are manufactured they will be replaced too.
Takata produced over 46 million wrong airbags and are now replacing them all over the world. In fact they had to go bankrupt due to this fact, however all faulty airbags will get replaced eventually, of course at no cost. Till then, please do not crash - if the airbags are engaged you may get even more wounded or even killed by metal parts shot at you from the airbag bay.
Old 12-20-2017, 10:04 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
USA Yaris airbag left driver's side recall possibility?
For USA made in Japan circa 2007/2008 or others having passenger side Takata airbag recall: Should we be waiting for the other shoe to drop for the driver's side? Bag made by someone else? When do we hear Microsoft's line: "Your vehicle will no longer be supported after year 2xxx. Here is a hundred buck coupon to spend on a great new Toyota vehicle. (certain restrictions apply) Because your vehicle contains safety relevant components with limited service lifetimes, Toyota is cooperating with your motor vehicle department in a mandatory vehicle retirement/collection program."
(Yaris airbag left driver's side recall possibility?)
Old 12-22-2017, 11:50 PM   #7
SirDigby
Drives: 2007 yaris 3 door
i can't read your letter.
Old 12-23-2017, 04:45 AM   #8
vivalaflam
Enthusiast
vivalaflam's Avatar
is it all Greek to you? :P
It's about TAKATA made airbags, which need to be replaced.
Cheers, George.
Any Yaris window switch recall updates? charles nelson DIY / Maintenance / Service 12 12-14-2012 07:40 PM
November 2009 - DFW Yaris Yak SaerinRhoe Southwest 6 11-17-2009 04:14 PM
November 1st Mosport DDT lapping event. 2009-18th Touge.ca event, Last event of 09! Touge.ca Canada 1 10-21-2009 02:50 PM
Yaris Seltbelt recall Carrot Top General Yaris / Vitz Discussion 7 01-28-2009 11:37 PM
November 2nd, Sunday - Mosport DDT lapping event, Last event of the season!! Touge.ca Canada 0 10-31-2008 01:45 AM
