Old 12-29-2017, 01:24 PM   #1
chrisgblues
Drives: 2007 Toyota Yaris
Door indicator light on - temporary fix
Thought I would post this "fix" for anyone in the same situation.
Someone popped the driver side door when they broke into my car, and now it doesn't quite close all the way. It closes enough to lock, but the door indicator light on the instrument panel stays lit all the time as if the door is ajar. From the outside the door "appears" fully closed, but upon closer inspection it's literally about 2mm ajar which apparently is enough to disengage the switch and turn on the light.
To fix this, I cut some one inch square pieces of duct tape and applied 3 or 4 layers on the lower part of the driver's door exactly where it makes contact with the switch on the frame. Now the switch fully depresses when the door closes and the indicator light is off.
The car is now 11 years old so I don't imagine I will spend the money to get the door re-aligned as long as this temporary fix works.
Thought this might help others in the same situation, thanks.
2007 Toyota Yaris 4-door Sedan - Manual Transmission. Flint Mica (dark grey metallic). About 18,000 KM per year
chrisgblues is offline   Reply With Quote
How do I fix the plastic under my front bumper? LeetViet DIY / Maintenance / Service 17 01-07-2017 04:52 PM
Fix or sell? Perpetuous_Dreamer DIY / Maintenance / Service 26 04-19-2013 11:07 AM
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 10:37 PM
Hey everyone...Did anyone get a FIX for the Oversteer Problem at fwy Speeds under war jay cobbs General Yaris / Vitz Discussion 0 06-13-2012 10:10 AM
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
