Old 01-04-2018, 03:17 AM   #1
perro547
Drives: 1
Off-road build
Hello I have a 2015 Yaris le (North American) and I was thinking what my best bet would be for an off-road build. I have 17 inch work emotion wheel but was thinking of going 15 inch with a nice fat tire. What about lift ? Barely any info on lift kits , I'd like a little more clearance. I would be doing light off-road nothing crazy.
Sent from my Moto G (4) using Tapatalk
perro547 is offline   Reply With Quote
Old 01-04-2018, 03:20 AM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
I’m curious too about this so I’ll follow this thread. I have no info about off roading these, but I do have some questions about your car here.
How did you tint your headlights? Did you paint or wrap your hood? Looks good though!
m.flores.0928 is offline   Reply With Quote
Old 01-04-2018, 09:29 AM   #3
OEM scion xd springs would likely lift it a bit
I lifted my echo on oem first gen scion xb struts/shocks
Old 01-04-2018, 10:52 AM   #4
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
i like the black hood look
Old 01-04-2018, 01:39 PM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
There are several off-road Yaris' and associated threads here on the forum, but are you really planning on going from that very attractive street machine to a grungy, off-roader?
It's just my opinion, so take it for what it's worth, but your car looks fantastic. Turning it into an off-roader would be a travesty.
Edit: Found a few old threads, but it looks like the image links are broken.
http://www.yarisworld.com/forums/sho...ht=road&page=2
http://www.yarisworld.com/forums/sho...light=off-road
On Instagram
On Wheelwell
Old 01-04-2018, 05:43 PM   #6
justanotherdrunk
Drives: 2016 SE
http://www.subcompactculture.com/201...aris.html#more
Old 01-04-2018, 07:54 PM   #7
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by justanotherdrunk View Post
That does look very But, yeah, I personally couldn't do that to that car. IMO, it's way too nice. If I was inclined, I'd go buy another similar but not quite so nice version and off-road it. That said, I'll likely never own that nice a Yaris. Although I could afford a new one, I'm too cheap and enjoy working on older ones.
Old 01-07-2018, 02:52 PM   #8
atomic_hoji
Drives: 2018 Yaris SE 5MT
Sub'd! Interested to see what you do with your Yaris if you dive down the rally / off-road rabbit hole!
^^^ So much good stuff on SubCompactCulture and YarisWorld..
Dig those wheels too man - going to make a note of those for when I get around to doing wheels and tires.
-- Adam
Old 01-08-2018, 04:04 PM   #9
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Check this out:
http://www.subcompactculture.com/201...ota-yaris.html
Old 01-08-2018, 04:30 PM   #10
lormagni
Drives: Toyota Yaris 1.33 SR
You could do something inspired to the rally version, something like this...
But I would not touch your car, it's perfect as it is!
lormagni is offline   Reply With Quote
Old 01-08-2018, 07:54 PM   #11
dogsridewith
Drives: 2007 2-door hatchback
rock crawler offroad gravel Yaris 2007
Photobucket blanked the mini-spare-out-front mock-up photo I posted here, but it is going to happen...for traction, flat cargo floor, and a resulting look I don't mind. Also want a second tow hook on the driver's side...two two hooks makes a tow-bar mount?
On the OP's late model, the spare might soften the visual effect of that huge grille. (Does that grille remove w/o pulling the whole bumper cover? prolly not.)
Old 01-09-2018, 06:24 PM   #12
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Nice! Im doing a rally style build with mine (got rear ended so haven't made progress). I like the XD idea, also I THINK that flat out suspension's kit can be used to lift it. not sure, but im sure you can call and go over specs with them
https://www.flatoutsuspension.com/products/sryaris
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 01-09-2018, 06:55 PM   #13
justanotherdrunk
Drives: 2016 SE
the 2 door looks great with the black wheels
silly off road build. hairdresserscar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-20-2014 11:45 PM
Dirt Road Yaris carlghoul Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-16-2011 06:22 PM
Yaris Off Road??? Rutherfordman General Yaris / Vitz Discussion 18 02-26-2010 10:13 PM
