Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Members Area > Suggestions - Feedback - Questions
Old 01-05-2018, 05:09 PM   #1
perfectillusion
Drives: Toyota Yaris
AC stop cooling at highway speed (> 100 kmph)
Hello Members,
I have toyota yaris 2012. Issue is with AC, it stops cooling at highway speeds or more than 100KMPH. Within city AC is working great.
Here are few tests i have done so far:
1. AC system is charged properly (checked with 2 different shops)
2. On highway when it stops cooling, I turn off AC and shift to Neutral gear and turn on AC again and it starts cooling immediately but stops after 2-3 minutes.
3. Car has clutch less compressor so clutch gap is out of question.
Recently changed evaporator core.
I have been told that compressor is bad but want to make sure if it is really compressor or something else causing it.
I would really appreciate your help and suggestions.
perfectillusion is offline   Reply With Quote
Old 01-06-2018, 05:10 AM   #2
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Chech the pressures of the ac system while reving the engine to the higway rpm range.
ncp13 is offline   Reply With Quote
air conditioning, yaris 2012
Highway minimum speed limit bentjazz Fuel Economy Forum 33 04-12-2011 05:38 PM
Vibration or shake at highway speed? evan DIY / Maintenance / Service 10 11-10-2008 09:23 AM
