Old 01-13-2018, 04:21 PM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
New (Bad) MPG record
I've been tracking my MPG's since I bought the car. Last fill up yielded a calculated 28.05 MPG. My worst yet! Still I figure that's no too bad considering it was well below freezing the entire time and I was only doing short trips of 5 miles or less, sometimes in snowstorms with the traction control kicking in the entire way.
My previous worst was 28.80, 3 years ago, also in the dead of winter.
For the record my lifetime average so far is 33.56. Best tank ever was 41.20.
Auto transmission, mostly city driving. Can't complain.
Old 01-13-2018, 07:21 PM   #2
dogsridewith
Drives: 2007 2-door hatchback
Cold winter tire pressure fuel mileage gas law
Check tire pressure...it is lowered by the ratio of temperature change (measured from absolute zero..."gas law"). Lower pressure creates more tire flex when the tire materials are stiffer because they are colder.
Old 01-14-2018, 03:27 PM   #3
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Interesting how much climate & other factors can affect MPG within the same basic model specifications. As a contrast, my lifetime MPG average over the last 2.5 years has been 40.9 here in Phoenix, AZ - All city/suburb work commute & weekend errand driving, with the A/C running approximately 3/4 of that time (& I never need to use the heater/defroster at all). My lowest was 32-33 MPG back when I first got my car new (break-in MPG?).
Kalispel is offline   Reply With Quote
Old 01-14-2018, 03:50 PM   #4
Even if the tire psi is the same, the car will use up more fuel. Most likely the defroster is being used, so that kicks on the AC, which consumes fuel. Cooler air is more dense, so more fuel will be used. Most likely the heater is also on, so that consumes more fuel. There's probably more wind for the car to push through, and he already mentioned (having to plow through) snow.
Old 01-14-2018, 05:05 PM   #5
OP is not complaining about or questioning his bad mpg. Simply stating the fact that he has just set a new record low for himself. As I have recorded all fill ups since I got the car, I too will periodically check what I was getting during the same period in prior years. So far what I see is no significant change meaning my Yaris is performing just as well, or badly, as it was when new.
Old 01-14-2018, 05:42 PM   #6
NYC-SE
NYC-SE's Avatar
Yep, exactly right. Just stating the facts. More than satisfied as to the MPGs with this car (and all other aspects as well).
Old 01-16-2018, 09:58 AM   #7
91mustang
Drives: Charcoal 2012 Yaris SE 5 Speed
my 12 se averages 34.5 mpg. i'm not easy on the rpms at all, so that is a contributing factor im sure.
91mustang is offline   Reply With Quote
Old 01-16-2018, 11:16 PM   #8
jayeh
Drives: '08 Yaris LB
That is about my average!
Only super long road trips bump up my average.
It's amazing how my car is 35-40 in suburban driving or 25-30 in the city.
jayeh is offline   Reply With Quote
Old 01-26-2018, 04:37 PM   #9
Caramine
my 14 se averages 20.3 mpg. i'm not easy on the rpms at all, so that is a contributing factor im sure. l live in Chicago
I think my car is a problem.
Caramine is offline   Reply With Quote
Old 01-26-2018, 07:12 PM   #10
jayeh
Sounds about right, especially if you have the windshield defrost on a lot.
Out in the suburbs driving around I can easily get 40+mpg but in real city driving (30 seconds between lights and 20-30 seconds of waiting for the next green) it's barely over 20 if I'm lucky.
Old 01-27-2018, 01:37 PM   #11
NYC-SE
NYC-SE's Avatar
Originally Posted by jayeh View Post
in real city driving...it's barely over 20 if I'm lucky.
Are you guys the full block burnout to the next red light types? Because those numbers sound awfully low. I've never been anywhere near that low and I think NYC qualifies as real city driving. Perhaps throttle body / MAF / PCV needs cleaning, or there is some other issue going on with your cars.
Old 01-27-2018, 07:16 PM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
are we talkin about driving down midtown competing against all the white vans and cabs and german cars?
aka red light, rev your balls off to 30mph until the next block. I do like 19 until i hit the west side hwy lol
Old 01-27-2018, 07:39 PM   #13
Secretblend
Drives: 2009 Yaris
How does heater use more fuel?
Unless I am wrong, more fuel shouldn't be used.
Secretblend is offline   Reply With Quote
Old 01-27-2018, 07:43 PM   #14
When HVAC is in defrost setting you are utilizing the a/c compressor. It kicks in in order to extract moist air inside the cabin to combat fogging up.
Old 01-27-2018, 07:47 PM   #15
Secretblend
Drives: 2009 Yaris
I understand that. To me, defrost is different than heater. :)
However defrost does use more fuel since A/C kicks in.
Thanks for clarify it.
Old 01-27-2018, 08:07 PM   #16
dogsridewith
Yaris HVAC rotary knob A/C Air conditioning defrost setting
Does A/C activate only on the most clockwise position/setting of that rotary HVAC distribution knob?
Old 01-27-2018, 10:59 PM   #17
jayeh
Any time I go on a road trip or stay in the suburbs for a while it jumps right back up.
I also totally spend way too much time in drive through line ups - that has to hurt it too.
Old 02-14-2018, 08:01 AM   #18
hichamaziz
Drives: my car is the best
hichamaziz is offline   Reply With Quote
2013 Yaris Really bad MPG??? Pmansbridge Fuel Economy Forum 8 03-05-2018 12:48 PM
Tiny Fiat 500 earns an unimpressive 30/38 MPG & 27/34 with automatic Kal-El Off-topic / Other Cars / Everything else Discussions 25 03-08-2011 08:48 AM
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 05:46 PM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 04:45 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 09:38 AM
