Old 01-17-2018, 03:42 PM   #1
eepp
Drives: Yaris 2008 RS
Yaris HB 2008: Cannot open back door, lock/cylinder move, but cannot release latch
It's a cold winter here in Montréal, Canada. We did hit less than -40°C.
I can't open my Yaris HB 2008's back door. At first I could not press the cylinder (once unlocked) to release the latch so I had the brilliant idea to hit it with a piece of 2x4 I had in the car, thinking it was only frozen. It got in instantly, but could not come back.
Now somehow I am able to turn the key in the cylinder both clockwise and counterclockwise, to move the cylinder back and forth (although it stays in the last position now, there's no spring-loaded action going on), but whatever I do, the door won't open.
First question: is there a way to open the goddamn back door from the interior? It seems like I have access to the assembly from a little rectangle opening on the interior side of the door. How could I release the latch?
Second question: what to do next? Considering my context, should I just buy a new cylinder or release button assembly like this:
I don't want to put too much money into this, so I don't care if I need a different key, or even no key at all (I can unlock with the actuator from the central Unlock button or even with a double-clockwise turn in the driver's door's lock I guess).
My guess is that the actuator and latch assemblies are still okay, only the cylinder is f*cked.
I'm asking here before investigating myself because it's freaking cold in here and I will need to rent an interior DIY garage lot to be able to work on this without entering hypothermia.
eepp is offline   Reply With Quote
Old 01-17-2018, 05:44 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I repaired both hatch latches on my two Yaris'. Both required removal. In fact, yesterday, I repaired the assembly on the 08. You can open the tailgate by accessing the little plastic rectangle insert you mentioned. Use a screw driver to push the small steel tab sideways. If you fold down your back seat and lie with your head on the floor, you can shine a light in there (I use my cell phone).
Once you get the hatch open, you can pry (carefully!) the plastic hatch panel off. A number of the clips will remain in the steel hatch. These can be removed by prying (again carefully) with a screwdriver. One 10 mm bolt holds the assembly in place. Once removed, there is a "C" retaining clip that can be removed and the lock cylinder will come out. Clean that thing like crazy inside and out. I used electronics cleaner. Then lubricate it well. I had to work mine gently back and forth in a vice to free it up. I put the short steel shaft in the vice and with channelock pliers, carefully worked the cylinder back and forth until it was freed up.
New latches are expensive and then have to be rekeyed. Both of my latches were repairable and yours probably is too. The little lever attached to the key cylinder that releases the latch mechanism on the car can skip out of position to the wrong side of the latch arm. This had also happened on my 08. I just repositioned it properly when reinstalling.
Old 01-17-2018, 07:03 PM   #3
eepp
Hey thanks 06YarisRS!
You're giving me some hope here.
As I wrote, if it's definitely broken, I don't care if I can buy a cylinder without its key... I'll just use the electric actuator to lock and unlock the back door.
I'll look into it, but how does this work exactly? I'm thinking this part with the cylinder (see photo) is linked to the latch with a cable? Or is it directly coupled and there are cables to the actuator?
I will follow your directions anyway. Do you know if the parts are the same for the 2-door and 4-door HB?
Old 01-17-2018, 07:39 PM   #4
06YarisRS
Happy to help. The button to latch mechanism itself has no cables. To be honest, I rarely lock the hatch and not even sure if my power lock button will control the hatch lock. It does have an actuator that is connected with a nylon mechanism. I will go test shortly to see if the door actuator will lock and unlock the hatch.
I expect that it's the same mechanism in both 2 and 4 door.
Here is a pic from when I fixed my 06 latch with some additions to help you understand how the mechanism works.
It's really quite an ingenious bit of engineering, but it's really prone to contamination and seizing, hence the need to regularly blast it out with a cleaner and then lubricate.
I wish now that I'd taken pictures yesterday to help illustrate for you the workings of the whole mechanism.
Old 01-19-2018, 07:50 PM   #5
eepp
Thank you for the information again, it helped a lot.
I'm documenting the process here with more photos.
This is indeed what happened, I guess when I hit the whole cylinder when it was frozen with a 2x4 stud.
When you remove the little rectangle cover on the back door's trim, it is quite straightforward and easy to open the back door. I guess this is the exact purpose of this little opening.
When the back door is opened, this image from another thread helped:
Start by removing the claw which is close to the latch. You need to pry the trim a little bit and press on the claw with a flat screwdriver to release the trim. Then work your way around with a big flat screwdriver and a flashlight, and make sure to always insert the flat head between the white plastic clip and the black trim, otherwise the clip "socket" on the trim could break. This happened to me, but only once! I don't understand why this trim needs three claws and nine clips...
This is the claw near the latch:
This is a white clip:
This is another "claw" (the other, white part stayed on the door's steel frame). Those claws are on the two corners near the car (opposite side of the latch). Make sure not to lose the white parts:
This is the whole removed trim (back view) with my dirty X230:
This is the latch (left), lock assembly (top, I don't really know the real name of this whole part), and actuator (bottom right):
This is the (first) issue:
The red part (on the lock assembly) should be above the yellow part (latch assembly) to press on it. When you press on the cylinder, the red part pressed on the yellow part. What decides if, when you press, the latch unlocks or not is the white part on the lock assembly and this is set by either the key or the actuator. There's a video below which shows how this works exactly.
Now it's okay:
This is the latch assembly with the three 10 mm bolts removed:
This is the lock assembly when the latch is removed:
Remove that 10 mm bolt and turn the whole assembly to remove it from the knob which still holds it, then you get:
That lock assembly was very dirty. I used brake cleaner and then a dry lubricant (which is rated for -65°C and one of the use cases is to lubricate a lock), always turning the key in the cylinder a lot to clean it as much as possible.
I don't have any photo of the assembly before cleaning as I was too excited to clean it, but for the purpose of this documentation, it doesn't matter. Here are the three parts, somewhat cleaned, of the lock assembly:
Here's a video showing how the lock assembly works. The white part I turn with my fingers, again, is controlled by the key or by the actuator so that both methods can lock and unlock the back door. It is indeed a nice piece of engineering. In my case, this cylinder was frozen and dirty, so it would not come back, even though there's a huge spring to push it back.
https://www.youtube.com/watch?v=TC1VRUgCXrs
Everything works fine and is smooth now!
Old 01-20-2018, 05:36 AM   #6
06YarisRS
Awesome writeup and video!
This will no doubt save many people money and aggravation as well as give them the satisfaction of completing a valuable repair themselves.
I couldn't see the whole label of the dry lubricant you used. Would you mind providing the details on that? Thanks!
Old 01-20-2018, 01:14 PM   #7
eepp
It's not dry at all, I missed the point. But it still works.
I don't have the can with me now, but it looks like this: PL-100 SUPER MULTI-PURPOSE PENETRATING LUBRICANT. Picked this at Canadian Tire for my fellow Canadian Yaris owners.
Old 01-20-2018, 08:43 PM   #8
06YarisRS
Thanks. I'm not really sure what's the best for these locks. I've heard everything from motor oil to graphite powder spray, but I'm just using Rust Check (the red can) for now. I try to give it a good long blast of ReleaseAll or electronics cleaner inside the key hole occasionally, then shoot some rust check in there.
Old 04-28-2018, 02:49 PM   #9
TYaris2010
Drives: 2010 Yaris
Just a note in the event anyone needs to know down the road...
the 2010 Yaris Sedan- the trunk lock cylinder is different then this. having issues w/ mine now and just pulled it. Its frozen.
Thanks.
TYaris2010 is offline   Reply With Quote
England to the Nordkapp and back in my Yaris zoidberg444 Photo-Video-Media Gallery 15 07-27-2020 08:09 AM
2008 yaris update Runner59 General Yaris / Vitz Discussion 1 08-14-2007 09:44 AM
