Old 01-20-2018, 05:54 AM   #1
Pinchlite
Drives: 2007 yaris HB
Need exact location of side marker wires/fusebox location
Will be installing XD mirrors today and need to splice into the side marker lights.
I would like to do this on the interior side if possible.If not I will splice into the side markers from underneath the fender.
P.S I have searched for location of sidemarker fuse/wires but cannot find definitive answear.
Pinchlite is offline   Reply With Quote
Old 01-20-2018, 05:43 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
Sadly i cant give you more info than found on
http://www.yarisworld.com/forums/sho...6&postcount=48
Old 01-20-2018, 06:09 PM   #3
Pinchlite
Thanks for reply.
I decided to splice into side marker lights,much simplier.
Now I need to get the mirrors to work.I only get the up position to work(power mirrors)
The XD mirror connector is smaller then the yaris one.I will swap the female connectors and trial and errror the wiring config.Hopefully I dont cook anything?
Old 01-20-2018, 07:16 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
is it? the connector is the same exact size as mine, and it worked perfectly when i plugged mine in. Advantage: 09+ yaris :P
Old 01-20-2018, 07:24 PM   #5
Pinchlite
Different size.
Someone else did the swap with same model car as mine(2007 HB)
I would like to know how he got it working,then again he may have had non powered mirrors?
I will take the passenger door panel off and then take it to toyota.Perhaps they have an idea of what wires are for what.I think if i just swap around wires I will/can fry the motor inside the mirror.I got the blinkers working as that was my main concern/priority.
I will post some pics of the connectors/wires first.Perhaps someone here can tell me what colors match to eachother.That post that explained the wiring is different colors then my xd mirrors and my yaris ones.
side marker LED Moses General Yaris / Vitz Discussion 1 05-20-2010 01:43 AM
LED Side Marker Installation Focus_Sh1ft DIY / Maintenance / Service 26 01-22-2010 06:14 AM
side marker lights yrsdrgn Cosmetic Modifications (Exterior/Interior) 154 07-10-2009 02:55 PM
Side Marker Lights Stoln General Yaris / Vitz Discussion 1 07-04-2007 02:44 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
