Old 01-29-2018, 02:35 AM   #1
elthong
elthong
Drives: YARIS 2014
AC not blowing cold air
hi guys! just a newbie here asking some help or tips from you.
i have a yaris 2014 model. early of september 2017 my AC start of having problems of not blowing cold air. a couple of days later i brought my car to shop and told the mechanics there about the problem. he start checking the pipes for he thinks that there are leaks on it but he found nothing, then he check the Freon ( refrigerant) and he told me that the refrigerant is low and needs only to add or refill. a minute later, it works the AC blows cold air.
then, yesterday while driving home i found the same problem again. i brought to the shop immediately telling the problem just like before. they just refill the refrigerant again and told me that after a couple of months i may be facing the same problem. the mechanics told me to change the EVAPORATOR for sure. do you think EVAPORATOR is causing the problem?
did you experience like this guys?
thanks a lot!
elthong is offline   Reply With Quote
Old 01-29-2018, 06:36 AM   #2
alanwagen
Yes you have a leak. They can put dye and show you the leak.
Old 01-30-2018, 06:51 AM   #3
mimelio
Drives: NONE
https://macsworldwide.wordpress.com/...99s-ac-system/
mimelio is offline   Reply With Quote
Old 01-30-2018, 07:20 AM   #4
zoidberg444
zoidberg444's Avatar
Either they can put UV dye in and identify the leak or you can take it to a better garage which has a sniffer. It can detect refrigerant leaking and bleeps so the leak can be identified. Sounds like it should be fairly noticeable.
UK to Nordkapp in a Yaris
Old 01-30-2018, 10:01 AM   #5
I don't know how them became so confident it is the evaporator if they cannot find the leak. Unless it is because they can find no leak so they assume it is under the dash at the evaporator.
Evaps are a pita and expensive to replace if you don't do it yourself. I'd either find a mechanic with a sniffer or use the due with uv light to really ensure the leak isn't under the hood
Old 02-04-2018, 03:53 AM   #6
elthong
elthong
Drives: YARIS 2014
yeah i will take it to other shop i will just wait till my a/c will blows warm air again... thanks you!
Old 02-04-2018, 04:05 AM   #7
elthong
elthong
Drives: YARIS 2014
yeah exactly they assumed the evaporator will be the problem coz they find nothing leak on the pipe. anyway, my a/c working better now. but just yesterday i notice there's a bad smell coming, it smells like a dust.
Old 02-04-2018, 04:07 AM   #8
elthong
elthong
Drives: YARIS 2014
no leak, they check already but found nothing. that's why the assume the problem is the evaporator.
FS: 2007 AEM Cold Air Induction System (USED - Package Deal) DJ_Trizzak Items for Sale by private party 12 12-07-2011 10:58 PM
Changing to cold air intake and insurance problem ExtremeCold Fuel Economy Forum 7 04-24-2011 08:20 PM
Changing to cold air intake and issurance problem ExtremeCold Performance Modifications 19 04-09-2011 05:15 PM
07+ Yaris Injen MR Cold Air Intake CorSport CorSport 0 07-09-2009 02:10 PM
yaris diesel,heater blows cold air.. cccecider General Yaris / Vitz Discussion 2 02-19-2009 02:25 PM
