#1 |
Drives: 1 Join Date: Aug 2017
Rear veiw camera install help
So I'm trying to install a rearview camera on a 2015 Yaris le. Those 2 bolts that hold the plastic cover in piece for the camera cutout won't come out. It just keeps spinning but does not get looser ?? I've been trying for a while and no progress. Also I'm trying to find which wire is the one I connect the reverse trigger to . I found these wired by my foot well not sure if it's even the right ones though.
![]() ![]() ![]() Sent from my Moto G (4) using Tapatalk |
![]() Drives: Yaris III Join Date: Nov 2020
hello,
have you solved this? Was this connector for rear camera? |
#3 |
Drives: 2018 yaris Join Date: May 2020
2018 Toyota yaris Thailand spec
Hi Guys i have 2018 Toyota yaris Thailand spec, i am having troubles installing my rear camera there isn't any RCA ports on the radio. what do i do.
#4 |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
From memory, when I installed my rear view camera, that connector is for the central locking. Some versions of the hatchbacks in some countries have a key operated lock in the hatch. This connector then signals the doors to unlock or lock when the hatch key lock is operated.
I wasn't able to find any wiring in the hatch for a rear view camera, and ended up running a video cable all the way back to the radio. I tapped 12 volts from a reversing light to power the camera and provide a switching signal to the radio.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Rear view camera | William's Yaris | Third Gen Yaris General Discussion | 2 | 08-26-2017 10:48 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
