Old 05-31-2006, 07:45 PM   #1
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Question Remote Turn On on Stock Stereo
Ok guys, I'm about to install an amp to my stock head unit (single CD). I'm using a line output converter to be able to use RCA wires. My only issue is: Where do I get the remote wire from the head unit to send the signal to the amp??? I looked for a dark blue or blue with stripe wire, but don't see it. Any help is greatly appreciated.
redglare45 is offline   Reply With Quote
Old 05-31-2006, 10:15 PM   #2
plushDJ
Drives: 2007 3 dr manual
When I did that with my last car the converter had a fifth wire that I used for the remote and it worked perfectly, don't know if yours does but hey.......
plushDJ is offline   Reply With Quote
Old 05-31-2006, 10:17 PM   #3
Supa Lao
Drives: '03 Murano SL AWD
Most stock radios do not have a remote turn on. Just use the acc wire.
Supa Lao is offline   Reply With Quote
Old 06-01-2006, 12:32 AM   #4
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
either use an acc wire, or like plushDJ said, most of the nicer "adapters" have the remote wire
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 06-01-2006, 12:56 PM   #5
punch
punch's Avatar
But using the acc wire, will cause the amp to be on even when radio isn't!
Old 06-01-2006, 07:16 PM   #6
Supa Lao
That's the only way to do it with a factory radio. Unless you buy a line out converter that also has a remote turn on.
Old 06-01-2006, 08:03 PM   #7
eight_heads
well you can always use an acc wire, but put it through a regular on/off switch first, then to the amp and if you have the car on but don't want the amp for whatever reason, just flip the switch off and the amp will turn off
'07 Yaris Liftback
Old 06-05-2006, 11:29 AM   #8
redglare45
redglare45's Avatar
Update
I ended up getting a meter and checking for the accessory wire on our stereo. On our stereo we have a blue harness that hooks up to the back of the stereo. I tested without the key in the ignition and found which wire had power without the key (light blue) and then when I turned the key to ACC, there was a wire (grey) that got power, only when the key was in ACC. So that's what I used for the remote. This way the amp turns on only in that mode. Thanks for your help guys.
Old 06-05-2006, 07:24 PM   #9
eight_heads
no problem
'07 Yaris Liftback
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
FS Various OEM keyless Remote riceboy Items for Sale by private party 0 04-14-2006 02:42 PM
