#1 |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
Passenger Side Low Beam Not Working
Hello! It has been a while since I posted in the forums, but I am still a happy Yaris owner
I lowered my car a couple of years ago, but almost never drove at night. I am starting to do that quite often now and while the lights let me see OK at night, I think some vertical adjustment can help. I was doing just that recently and noticed the passenger side low beam does not work. I tried adjusting the cables making sure they are tightly connected, with no luck. To clarify, the passenger side low beam is the only beam that does NOT work. The driver side low beam works and the high beams on both sides work. Would the general steps be to make sure connections are good, check fuse, and if not replace the bulb as a last resort? I noticed the passenger side headlight housing is getting a bit foggy too. Can that be an indicator of anything? Also, regarding the original topic. I wonder what process everyone else has used. The one I have been referred to the most is to wait until it is dark out, be on flat ground, and try to get the beams straight ahead. Is this reasonable for me doing self-alignment? Thank you! |
It's a dual filament bulb and the low beam filament is burnt out. Replace the bulb.
#3 |
#4 | |
It was way easier than I expected. Now I just can't figure out how right my alignment is. There are not a lot of flat spots around me. |
#5 |
If the alignment was OK before and the new bulb is seated properly then it should be still OK.
The local automotive certification company (the one that does regular state car checks) offers the alignment check and set for some 9 USD. And they use the professional equipment - regloscope etc. This is also part of the spring checks that many car service centers offer after every winter here, with total cost about 10 USD. For that price I would never bother about that. |
| Looking for Passenger side Fender! | Marthos | Willing to Buy by private party | 1 | 07-21-2011 08:13 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| WTB - Passenger Side Seat Bracket | lunjiaow | Willing to Buy by private party | 3 | 09-08-2009 05:03 AM |
| Passenger side airbag question | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 01-03-2009 07:54 PM |
