Old 03-01-2018, 10:13 AM   #1
YodaBird
Drives: Gray
Rattle sound never experienced prior to maintenance check at Toyota
I recently visited Toyota for a maintenance check. After the visit I've noticed after a typical drive then parking the car, only when the car is in drive and my foot is on the brake, there is a loud sound, sorta similar to a rattle; I was informed, rather recommended during the inspection that the roters need replacing and the brakes need the result removed as a result of gradual driving overtime along with road salt.
Could the rattling be the cause of the roters along with the rust behind the brakes or is it something else ?
YodaBird is offline   Reply With Quote
Old 03-01-2018, 12:46 PM   #2
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
Probably an exhaust heat shield
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 03-01-2018, 01:02 PM   #3
Agreed.
Reach in behind the engine and see if you can wiggle the exhaust manifold heat shield. Mine rattled horribly with foot on brake at stop lights when its mounts had finally deteriorated. If it is still firm, crawl under the car and see if any of the other shields placed along the exhaust route are loose.
Old 03-01-2018, 01:43 PM   #4
stykerdk
Yaris Hybrid Limited 2015
Or as they said your brake pads is worn down and now the acoustic indicator is touching the disc when braking.
There is a nice pic here.
http://www.jeeppatriot.com/forum/5-j...ndiciator.html
C-HR 1,8 Hybrid premium 2020
Old 03-01-2018, 09:54 PM   #5
YodaBird
Drives: Gray
Agreed.
You wouldn't be able to take a picture so I can see exactly where to look ?
When the car is in neutral or reverse there is no sound.
When driving for a while then putting the foot on the brake, the rattle sound begins or simply just reversing a few inches when the car is running in a parking lot then driving a few inches followed by putting the foot on the brake the sound will begin.
Old 03-02-2018, 12:00 AM   #6
jayeh
Drives: '08 Yaris LB
So, I have the exact same thing happening!
If the mounts have deteriorated how can I fix it?
jayeh is offline   Reply With Quote
Old 03-06-2018, 08:20 AM   #7
hichamaziz
Drives: my car is the best
thank you all members for help
hichamaziz is offline   Reply With Quote
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 11:27 AM
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Check Out GENERATION TOYOTA gentoyota General Yaris / Vitz Discussion 0 06-14-2007 08:53 AM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
