Old 03-15-2018, 05:33 PM   #1
Yaris709
Drives: 07 yaris
Having brake issues
Having issues with the brake pressure in my 2007 yaris sedan. When I first start up the car I have no brake pressure and can't stop. Once i get going down the road a bit the brakes work perfect again. Seems to only happen for a few seconds after start up and driving. Anyone have an idea what could my problem be?
Yaris709 is offline   Reply With Quote
Old 03-15-2018, 08:16 PM   #2
ex-x-fire
So, you don't have any power assist?
Old 03-15-2018, 09:05 PM   #3
Yaris709
Drives: 07 yaris
Nope I loose break pressure (and car can't stop) for a few seconds on a cold start of the car. After driving for a few seconds it seems fine again
Old 03-16-2018, 08:02 AM   #4
ex-x-fire
I guess you can look for wet spots anywhere. My guess would be the master cylinder is bypassing.
Old 03-16-2018, 01:41 PM   #5
Is the brake pedal hard, or you push and it goes to the floor?
Sent from my SM-G930W8 using Tapatalk
Old 03-16-2018, 02:46 PM   #6
Acura_reaper
Drives: 2007 silver auto stock sedan
I just rear endend a focus yesterday cuz my brakes went to the floor. Broke my grille but did nothing to their car go figure.
Sent from my VS996 using Tapatalk
Acura_reaper is offline   Reply With Quote
Old 03-16-2018, 02:48 PM   #7
Then your master cylinder must have issue IMO.
Old 03-16-2018, 02:57 PM   #8
Acura_reaper
Ill have to check it. I replaced my front brake pads bled the brakes snd checked fluid and lines it looked good. it seems a lil bit stiffer but my pedel is spongy.i dont know. Their really ait much else it could be. Maybe back brakes idn
Old 03-16-2018, 03:02 PM   #9
Pull hand brake if you are not getting brake response...
IMO you shouldn't have driven your car when you knew you had brake problems.
Brake fluid should be changed after a while AFAIK.
Old 03-16-2018, 04:43 PM   #10
Acura_reaper
Your right but when you have to go to work you go to work
Old 03-16-2018, 05:21 PM   #11
No you don't, or you find another way to get to work and not put others or yourself in danger.
Old 03-16-2018, 05:37 PM   #12
Acura_reaper
U dont know my situation so stop trying to tell me what i should do and help me fix my brakes or shut up
Old 03-16-2018, 05:46 PM   #13
Garage. Check master cylinder. Told you already.
What if you just FUCKING DIED while going to work with a broken car? Hope you kill someone with your car.
Old 03-16-2018, 09:20 PM   #14
Yaris709
Drives: 07 yaris
Alright guys enough with the arguing haha I'm just wondering why my cars brake pressure was temporarily lost for a few seconds. On a side note it was fine today never had any trouble at all. This is a weird problem
Old 03-17-2018, 09:43 AM   #15
dogsridewith
Drives: 2007 2-door hatchback
Yaris brakes malfunction
OP will get better advice here if e answers this question. (A pedal on the floor or a high pedal w/ failed boost will both reduce "brake pressure," but would likely have different causes.)
Old 03-17-2018, 09:51 AM   #16
High brake is likely failed vacuum, but a pedal to the floor is either air in system or master cylinder.
Now, op already checked for brake line leak, and bled. Provided he did good/proper maintenance, all I can think of is the master cylinder having issues.
Eitherway, OP said his pedal went to the floor, I did suggest it was the master cylinder, stop driving the car as it is very dangerous.But well, looks like I know nothing, so I'll just let OP drive his car around trying to kill some innocent people
Old 03-17-2018, 11:37 AM   #17
Please note that there are two individuals with brake issues contributing to this thread.
The OP did not make the statements you are referencing.
Old 03-17-2018, 11:40 AM   #18
Nice thread hi-jack. SMH
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
Help! Brake light issues! Prohibit DIY / Maintenance / Service 17 05-23-2011 08:33 PM
Rear brake adjust issues 07 Hatch Tardis DIY / Maintenance / Service 4 03-20-2010 06:49 PM
