Old 03-21-2018, 08:08 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Slightly Low Coolant, Should I Flush or Top It Off
Hello,
Recently my friend noticed the coolant in my Yaris was a little bit below the line LOW line, but I only have 70k miles so it is not due for a replacement. I want to fill it back to the appropriate level, but am not sure of what type/brand of coolant was put in previously. Any idea of what are the best steps I can take here to avoid any issues? I would have no problem flushing the system, but ideally would like to avoid it.
vaironl is offline   Reply With Quote
Old 03-22-2018, 01:38 AM   #2
komichal
Buy yourself a mixture with water 1:1 of G12+ (pink one) and pour it in. The brand is not that important.
For a full flush the guys here would recommend to go only with OEM Toyota coolant but if you just need to add a bit then you can use anything. I did a full flush recently and used Sheron as the Toyota stuff costs a fortune while there is no measurable difference.
Old 03-22-2018, 05:02 AM   #3
vaironl
vaironl's Avatar
Thank you for the advice, gonna get it ASAP! I did notice the Toyota coolant will cost a pretty penny!
Old 03-22-2018, 06:44 AM   #4
Keep in mind the cooling system in the yaris is not a sealed system so losses due to evaporation do happen. Every year you'll probably find you are down a few ounces
Old 03-22-2018, 07:48 AM   #5
ex-x-fire
Originally Posted by vaironl View Post
Hello,
Check your water pump, sometimes they leak and then stop. You'll likely see a dry crusty stain, red colored.
Old 03-22-2018, 08:44 AM   #6
vaironl
vaironl's Avatar
Got it, I'll make sure to get the reservoir as close as possible to the full line.
Will be checking for this, thank you for pointing it out. Hopefully, it is just as tmontague said and it was due to evaporation.
Old 03-22-2018, 09:43 AM   #7
komichal
I remember once quite a gulp of coolant "disappeared" from my coolant reservoir in one week or so. I poured in some distilled water and it has not moved a bit since then. It is been on the same level over a year already. Who knows why car spitted that out before.
Old 03-23-2018, 08:23 PM   #8
SirDigby
Drives: 2007 yaris 3 door
^^^yes. top off with distilled water. it's like $0.60 a gallon.
Old 05-23-2018, 09:20 AM   #9
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
Just make sure what you put in there guys ,
mixing OAT coolant with HOAT coolant makes a reaction turning your coolant to a Jello like substance ==> big troubles getting that removed from Inside engine .
Kazimodo is offline   Reply With Quote
Coolant flush procedure? BennyLava DIY / Maintenance / Service 24 11-20-2014 05:11 AM
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Query re: low level coolant indicator tracey540 General Yaris / Vitz Discussion 2 05-12-2010 06:01 PM
