Old 03-28-2018, 12:31 AM   #1
Aj353519
Drives: 2008
2008 won't start after front end collision
Crashed my 08 Yaris today and the engine was running still. After I turned it off it won't start and the gearshift will not come out of park. Also no power to the cigarette lighter socket and no display for mileage etc. Key fob will not lock or unlock the car. Was a front end collision. Other than the broken plastic bumper and the coolant leak there is nothing wrong with it. It's on the side of the highway and I want to move it without towing. Is this an immobilizer issue or something More. The airbags did not deploy.
Aj353519 is offline   Reply With Quote
Old 03-28-2018, 02:06 AM   #2
B.B._07
Drives: 07 5dr
Sounds like you where in a front end collision and the battery or the connections may have been damaged. I'd check if the battery hasn't been cracked in the collision, or the terminals damaged or knocked off in the impact. I'd also check the 60A and 120A fusible links in the fusible link block located right by the battery positive terminal.
Old 03-28-2018, 07:38 AM   #3
Aj353519
Drives: 2008
Well that's the strange thing. Get beeping with the door open and key in. And a battery and oil indication lights in the acc position. Battery is fine. Has to be something with the airbag system or immobilizer. Car was running fine and gearshift worked.
Old 03-29-2018, 12:33 AM   #4
Aj353519
Drives: 2008
Was a loose terminal on the battery. Car is fine.
anyone have a front bumper for my 2008?
Old 03-29-2018, 12:34 AM   #5
Aj353519
Drives: 2008
Was the battery terminal loose. Hammered it on. Car is fine.
Anyone have a front bumper for my 2008?
Need 2008 Yaris sedan OEM front bumper lip spoiler. Only the lip not the bumper. Chewy Willing to Buy by private party 1 04-17-2017 05:47 PM
Front end mask RocknRollRon Items for Sale by private party 7 09-02-2007 06:12 AM
Bra or front end protector? Yaris S N9QGS Cosmetic Modifications (Exterior/Interior) 6 07-13-2007 08:29 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 12:11 AM
For trade, polar white front end Walter California 0 01-08-2007 11:38 PM
