Old 04-01-2018, 02:58 PM   #1
Dudejustus
Drives: 2007 Toyota Yaris Base
Power window wiring diagram
Greetings all!
So my girlfriend has a 2007 yaris hatchback and the driver side door needed to be replaced due to an accident, So i pulled one from a scrap yard and did the swap. The only problem is the replacement door has a powered window instead of manual crank. Id like to see if i could get the powered window working as i don't really feel up to swapping the window mechs.... Does anyone have a wire diagram for the power windows or know which wires are 12v, ground or go to a relay? Thank you in advance!
Dudejustus is offline   Reply With Quote
Old 04-02-2018, 03:49 PM   #2
B.B._07
Drives: 07 5dr
It might be as simple as plugging the swapped door wire harness in and getting a power window relay and fuse. Take the drivers side kick panel off to see if the 6 additional power window wires and the gray ecu wire are pre-wired into the car past the drivers door wire harness. That was the case in a 05 Matrix I did the manual to power window swap, so inside the car I just had to add a fuse and relay to the factory spots in the interior fuse box.
Old 04-03-2018, 01:02 AM   #3
Dudejustus
THANK YOU BB07! So it looks like i just need that pink 30A fuse and need to figure out how to jump off of it because the car doesn't have the wire harness for the gray, pink, white wires. Also, does anyone know where the relay is located? I cant seem to find it, i'm going to see if those power fuse pins give 12v.
2013 Power Window already has a fuse? SecondYaris Third Gen Yaris General Discussion 0 03-06-2016 07:12 PM
Power window failure YarTrek DIY / Maintenance / Service 13 11-25-2013 12:38 AM
NEED WIRING DIAGRAM FOR FCON MINI AND AFA Faraz_Shaikh Forced Induction Forum 1 10-25-2010 12:59 PM
Power window motor BMGYaris DIY / Maintenance / Service 10 01-22-2010 09:09 PM
