Old 04-02-2018, 11:44 AM   #1
Pinchlite
Drives: 2007 yaris HB
Loose/slack/play ebrake lever....
The tightness setting is at its tightest under the handbrake itself.I removed drums and have adjusted star so shoes are slightly dragging on inside of drum.
The brake tightens and holds car fine but there is still dead space in the brake lever.Hope this makes sense and need some suggestions.
Basically there is floppy play(Zero tension) for about 2-3 inches before the lever has tension.Again the shoes drag on the inside of the drums.
Pinchlite is offline   Reply With Quote
Old 04-02-2018, 12:35 PM   #2
There should be come slack picked up in the first few inches (2-4clicks) or else your brakes would be dragging way too much.
Other option is to loosen the adjuster underneath your ebrake all the way and then readjust your drums. Then you can fine tune with your ebrake adjuster.
I personally never touch the e brake adjuster I just adjust at the drums a few times a year
Old 04-02-2018, 02:57 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
Loose/slack/play ebrake lever parking emergency star wheel
The adjustment spec given by Toyota is a particular number of clicks to obtain a tight setting.
Parking bake lever travel too much, how to adjust tamrat General Yaris / Vitz Discussion 0 01-23-2018 11:21 PM
"Komfortblinker" (touch turn signal lever once, car blinks three times) Kar98 In Car Entertainment + Electronics (audio / video / alarm) 5 03-14-2014 06:26 AM
Parking Brake Lever Liu997 Willing to Buy by private party 10 03-10-2011 04:16 AM
door handle (lever) is popped out slightly jstantherprsn DIY / Maintenance / Service 0 10-15-2010 04:38 PM
Broken 40/60 Back / Rear Split Seat Handle / Lever alex_melodymaker DIY / Maintenance / Service 9 10-31-2009 04:55 AM
