Old 04-08-2018, 01:45 AM   #1
yotoya
Drives: 2008 sedan automatic
How can I play my Android phone's audio directly into my Yaris's basic audio system?
I recently bought an 2008 Yaris. It comes with an audio system that looks like this
It comes with a CD slot, FM and AM. But it can't play the stuff from my Android smartphone. What are the options to make use of the car's speakers?
I prefer an inexpensive solution.
I understand I can buy an FM transmitter. But perhaps it would be better if there was some way to connect the smartphone to the audio system by a line. Is there something at the back of the audio system that lets me connect it directly? I think the audio would be much better than by FM transmitter.
yotoya is offline   Reply With Quote
Old 04-08-2018, 10:25 AM   #2
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
plug it in the aux port...?
i dunno about 2008, but my 2010 base has an aux port in the one storage pocket
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-08-2018, 10:47 AM   #3
castles
Drives: 2008 Yaris
My aux port, 2008 3 door hatchback, is on the center console next to the parking brake and the stock stereo is clearly marked with a Disc-Aux button. Is your owner's manual in the glove box? There is a section about the audio system.
castles is offline   Reply With Quote
Old 04-08-2018, 11:07 AM   #4
I believe with that particular HU you are out of luck. There is no aux capability.
Old 04-08-2018, 11:27 AM   #5
yotoya
Castles & malibuguy, I'll check user manual and see if there's an auxiliary port.
Weeyari, you may be right.
Old 04-08-2018, 12:23 PM   #6
yotoya
I checked the user manual, and it didn't mention an auxiliary/line port.
I see no ports on center console or in glove box either.
Is there any way I can splice my phone's audio into car's audio system? (Preferably something direct... In other words, not FM transmitter)
Old 04-08-2018, 03:49 PM   #7
Runethecursed
Drives: 2009 Yaris S
I use an AM/FM transceiver. buy this one.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
High quality, sexy german male voice tells you its connected, and it has noise cancelation so you get alot of harmonic resonance from the ungrounded chassis canceled out.
Runethecursed is offline   Reply With Quote
Old 04-08-2018, 05:24 PM   #8
No because you have no ability to change input selection on the head unit to aux.
eBay is probably littered with Toyota OE units that do have an aux port for cheap.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
