Old 05-30-2007, 03:38 AM   #1
Possible Damage?
i solved my problem, yet again. i knew that it couldn't be all that the amp was giving, so i rechecked the wiring just now (it's past midnight here, lol). and i was right, my friend hooked up the RCA cables to the aux cables of the HU. so i swapped those to the rear cables, and now my subs works just fine. being midnight, i couldn't fully test it out or even tune it perfectly (do that later today, along with buying a remote signal wire). now my question is: could having the RCA hooked up to the aux cables, and not the rear cables, cause damage to anything, i.e. sub, amp, etc? thanks again.
Old 05-30-2007, 03:47 AM   #2
BlueFlash
wa do dem
BlueFlash's Avatar
Drives: 2007 blue Lb
no because on your deck the aux is and input right so then there was no signal/power going to your amp then to your subs
BlueFlash is offline   Reply With Quote
Old 05-30-2007, 03:57 AM   #3
weird thing was that there was a tiny bit of power getting to the amp and sub, that's why i could barely hear the sub at all.
Old 05-30-2007, 04:06 AM   #4
BlueFlash
wa do dem
BlueFlash's Avatar
did you use a dvom to check voltage or could you really hear the subs some times they can be off but seem on due to the bass of the stock speakers if you did hear them i dont know how to expain that the rcas are the only source of signal
Old 05-30-2007, 04:14 AM   #5
yeah, i could hear and feel them when they were connected to the aux jacks, but barely. we checked the voltage, and got nothing, then again we checked my friend's too, and got nothing (his meter must be broken). really dunno how to explain it too, but hopefully no damage occurred.
Old 05-30-2007, 04:19 AM   #6
BlueFlash
wa do dem
BlueFlash's Avatar
well if you got no voltage then there wasnt any if there was you would have one screwie deck i wouldnt worry because its highly unlikely you got out put out of and input reading no voltage, what did you install 12's
Old 05-30-2007, 01:29 PM   #7
okay, probably didn't cause any damage (whew)...
Old 05-31-2007, 12:17 AM   #8
RogueYaris
Drives: 2015 Abs Red
don't forget there should be fuses all over the place to prevent things from getting fried even if you screw up and plug the stuff in wrong.
RogueYaris is offline   Reply With Quote
Old 06-02-2007, 02:45 AM   #9
yeah, there's fuses on the HU, power cable, and the amp itself.
damage from factory 91drggndime General Yaris / Vitz Discussion 4 03-14-2007 02:49 PM
Rust concern due to damage? Jem_hadar Wash, Wax, Detailing, Exterior Repairs 6 03-03-2007 08:17 PM
Rear wheel area, a dent... Rust concern? Jem_hadar General Yaris / Vitz Discussion 9 02-27-2007 01:03 PM
US Yaris crash test are in oehtam General Yaris / Vitz Discussion 39 12-30-2006 09:15 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
