Old 04-19-2018, 03:05 AM   #1
danbingham
Yaris 2007 Standard Stereo Wiring
Hi all,
I took the standard radio out last night to replace this with an Xtrons unit. Things seem to go well, and connected the majority of the wires using connector adaptors, apart from this one shown at the far right (see attached).
Does any know what this connector is for?
danbingham is offline   Reply With Quote
Old 04-20-2018, 06:18 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by danbingham View Post
Hi all,
I'm going to guess amplifier trigger wire, back up camera/DVR wires, brake detection wire. Not sure, but your manual doesn't have a pinout diagram?
Old 04-20-2018, 09:24 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
They appear to be the SWG, SW1 and SW2 wires. These are the wires from the steering wheel mounted radio controls for volume, channel/track change and input select.
Here's the pinout diagram I have.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 12-07-2020, 05:26 PM   #4
perozo.rogelio
Drives: Toyota Yaris 2007
Hi, Does it work for Toyota Yaris 2007?
perozo.rogelio is offline   Reply With Quote
Old 02-14-2021, 08:23 AM   #5
Yarisgent
Hi all new to this but I have a problem with the TNS400 say nav. I have retro fitted exchanging the old standard radio with the sat nav unit. Problem is I do not have the 20 pin to 8 pin adapter any one know the pin orientation of the 8 pin on the Head or where I can get the 20 pin to 8 pin tyco amp adaptor.
File Type: jpg 9DE51683-86EA-4798-8F35-0B626B685B31.jpg (87.7 KB, 93 views)
Yarisgent is offline   Reply With Quote
Is a 2006 Yaris coupe different from a 2007 Yaris coupe? fuzzybabybunny General Yaris / Vitz Discussion 0 02-25-2016 07:09 PM
Yaris TS 2007 French : sub with stereo orginal ? Rolex35 In Car Entertainment + Electronics (audio / video / alarm) 2 01-07-2013 02:47 PM
