Old 04-20-2018, 07:56 PM   #1
bri62
Drives: WHITE YARIS
Rear hub bolt torque value?
Does anyone have the torque value for the rear hub bolts?
bri62 is offline   Reply With Quote
Old 04-20-2018, 09:14 PM   #2
67 ft/lbs
Old 04-21-2018, 03:55 PM   #3
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
Interesting, I was after this spec last week. I had it as 41 ft/lbs through various internet sources.
I suppose I should bump them up to 67 ft/lbs.
Thanks!
Ronnie V is offline   Reply With Quote
Old 04-21-2018, 04:41 PM   #4
Ronnie V
While we are at it, whats the torque spec for the trailing arm bolts?
Old 04-21-2018, 07:04 PM   #5
Assuming by trailing arm bolts you mean the main axle bolts that go through the bushings and hold the axle to the body of the car - they are also 67 ft/lbs
I would definitely re torque your hub bolts, they see a lot of vibration and you don't want those backing off
Old 04-22-2018, 12:28 PM   #6
Ronnie V
Very Good. Thanks!
I will go back and torque everything to 67 ft/lbs. The car is sitting on the lift waiting for me to find some time to get the new exhaust system installed.
How to remove rear wheel hub? Gpav6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 08-01-2014 10:38 AM
Left lower suspension arm rear bolt broken. Kramruuk DIY / Maintenance / Service 1 07-07-2012 05:42 PM
Rear hub spacers Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-01-2010 11:54 AM
