Old 04-22-2018, 02:48 PM   #1
hmsailor
Drives: 2015 yaris hatchback
spoiler install
my 2015 4dr LE Hatchback didnt come with a spoiler. if i get a toyota oem spoiler, is drilling required for installation?
hmsailor is offline   Reply With Quote
Old 04-22-2018, 03:01 PM   #2
The one you have pictured can be held on with 3M tape only.
Old 04-22-2018, 11:30 PM   #3
SirDigby
Drives: 2007 yaris 3 door
it can, but if you look at the little covers underneath; there are brackets in there that can be installed by drilling a hole and using included plastic inserts. (i used metal threaded inserts and a bolt) also, i believe there are 2 plastic arrow clips on the spoiler that will have to be removed if you don't drill alignment holes. (if installed from factory)
Old 04-23-2018, 12:01 AM   #4
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
heres what mine looks like with the hatch up
probably doesnt help much
Old 04-23-2018, 10:38 AM   #5
hmsailor
even when therebare tabs underneath as seen in the pic? the reason i asked is because the cs rep told me that there is no "special" drilling required.
Old 04-23-2018, 10:40 AM   #6
hmsailor
so if i buy a factory oem part, do i need to drill?
Old 04-23-2018, 10:53 AM   #7
Factory installed would be drilled. I'm saying, for that particular spoiler, 3M tape would do the job. It's a scary thing to take a drill to your body panels.
Old 04-23-2018, 06:39 PM   #8
hmsailor
im just a little lost because the spoiler in the pic is a factory toyota oem part.
Old 04-23-2018, 08:31 PM   #9
SirDigby
you don't have to. the covers clip into place. they install the bracket for safety, but the drilling is easy;
-hand tighten nuts on bracket, spoiler side
-hold spoiler in place where it is live forever
-mark holes with marker
-remove spoiler and drill holes
-put tape on the drill bit at 5mm if you are scared of drilling too deep.
-use touch up paint around bare metal
it's super easy to do, but if you use just the tape, make sure to use some really good stuff, like VHB 3m
Old 05-26-2018, 07:26 PM   #10
DarkShadowFox
i just got the spoiler off the internet with no guides and a broken LH cover XD how do i install this is there one way it fits on?
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
DIY Hatchback Spoiler Install skootdog Cosmetic Modifications (Exterior/Interior) 29 06-14-2016 04:44 PM
What would the labor costs be to install a spoiler? JerseyJeff84 Cosmetic Modifications (Exterior/Interior) 11 08-22-2010 07:24 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-11-2007 11:02 PM
