Old 04-24-2018, 10:57 AM   #1
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Probably been covered before
2010 Yaris hatchback , 100,000 miles , automatic transmission.
Issue #1 : Not all the time ,but when I stop at stop lights / signs , the engine shakes as if it's going too stall out. Out on the road it's fine. I'm going to clean the MAF sensor. The battery is 18 months old.
Issue #2 : Speaking of the battery. Over the last several months I've noticed acidic buildup on the positive terminal / post etc. I've used baking soda and water to clean away the crud. BUT , I can't get the positive terminal / clamp to come off of the post. I've loosened the clamp nut and the other fasteners at the rear of the post but it won't budge! , what the heck?. I'm not a noob per se regarding general maintenance. If I place any more muscle on this clamp I'm concerned I'll break something. And yes , the negative clamp has been removed from its post. TIA.
frog13 is offline   Reply With Quote
Old 04-24-2018, 12:12 PM   #2
I'd let some on blaster soak in it for a while, spray every 15 mins and let gravity pull it down into the seized point.
Keep in mind the 1nz idles low and tends to have a rough idle from time to time, especially when a high auxiliary load is placed on the engine. Clean the maf, throttle body and use a scanner to check fuel trims during idle and at 3k rpm to check for vacuum leaks. And lastly, cleaning the battery can help
Old 04-24-2018, 01:16 PM   #3
frog13
Tw200--excellent!
Thank you for the reponse.
Understood on all advice on cleaning various items , battery was going to be first item , but...... .
Idle . Understood on low idle , but this engine is shaking as if it's blood sugar is low or its going thru withdraw symptoms : ). I'll soak with blaster and see what happens. Thanks again.
Old 04-24-2018, 05:22 PM   #4
I don't know the sequence of events that have taken place but keep this in mind. If the battery has been disconnected long enough for the ECU to drain residual charge, the engine will idle rough at extremely low rpm until such point as the ecu has relearned proper trim levels.
Old 04-24-2018, 06:02 PM   #5
frog13
Tw200--excellent!
Understood. This rough idle condition existed well before the battery was disconnected.
Old 04-24-2018, 08:31 PM   #6
castles
Drives: 2008 Yaris
Engine mounts? Maybe?
castles is offline   Reply With Quote
Old 04-25-2018, 04:38 PM   #7
B.B._07
Drives: 07 5dr
If your battery terminal is hopelessly stuck you can try a battery terminal puller. They cost about 15 to 20 dollars and a bunch of companies like Lisle, Gearwrench, and OTC make them.
https://www.amazon.com/OTC-4611-Batt...erminal+puller
For the idle issue I would try cleaning the MAF sensor. You can buy the MAF sensor cleaner or just use regular brake cleaner.
Old 04-27-2018, 11:43 AM   #8
frog13
Tw200--excellent!
Gotcha 07.......thank you
Old 04-27-2018, 11:44 AM   #9
frog13
Tw200--excellent!
Motor mounts. Highly doubtful, but thanks for chiming in. Appreciated
Old 04-27-2018, 11:46 AM   #10
frog13
Tw200--excellent!
Dang it.....why's the print so small , what next, my feet gonna get longer.....hahahaha :)
Dipstick covered in oil-help! DaveG DIY / Maintenance / Service 34 05-05-2011 07:42 PM
