Old 04-29-2018, 10:42 PM   #1
drt1120
Drives: 2009 3dr Red 5spd
Differential Repair
The differential on my 2009 Yaris with manual transmission is failing after 210K miles. I have removed the transmission and have the differential out and the gears are loose and worn along with bearings. I am having a hard time finding the parts to repair the differential. Is there a kit out there that I can't find to repair the differential or can i buy an assembled differential and drop it in? Trying to figure out the parts has been more trouble than getting it apart.
drt1120 is offline   Reply With Quote
Old 04-30-2018, 07:34 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Toyota Yaris manual transmission repairs
I think the complexity of transmission repairs (including numerous special tools) on this sort of vehicle, how long tranny's last, and how many cars are supplying reasonably priced used ones below 100k miles make even opening manual transmissions a rarity.
Old 05-01-2018, 01:06 AM   #3
B.B._07
Drives: 07 5dr
FWD manual transmissions really are not that complex on the inside (unlike automatic transmissions). Rockauto sells some of the bearings, but for the gears it's a low failure part so your only option maybe new through Toyota. I think a better option would be a good used transmission from a junkyard. If you're to pull one yourself most self serve junkyard charge around $100 for a manual transaxle (aka FWD transmission) and many of the self serve yards have occasional 40-50% off weekend sales. Then you can use it as a donor or just straight swap it.
Old 05-05-2018, 12:30 PM   #4
drt1120
I have considered getting a used transmission from the self serve junkyard but not excited about having to get it out in the yard on my own. Also finding a manual Yaris in a junkyard around me is rare.
Old 05-30-2018, 09:45 PM   #5
drt1120
Well I got lucky and found a transmission in a salvage yard for $77 and it is back on the road again.
Old 05-31-2018, 07:14 AM   #6
dogsridewith
Good job. What were the hardest steps in the transmission swap?
Old 06-01-2018, 02:23 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I haven't been on the forums much lately, otherwise I would have been happy to part with one of my spares. Glad to hear you got it sorted out!
Old 06-01-2018, 05:42 PM   #8
zoidberg444
zoidberg444's Avatar
That's good news mate. If you replaced the clutch while you were at it you should have another 100,000+ miles of trouble free driving ahead. I've never heard of the diffs failing in the Toyota FWD boxes. Only issues I've seen with them is bad synchro rings.
UK to Nordkapp in a Yaris
My DIY door ding repair NYC-SE Wash, Wax, Detailing, Exterior Repairs 5 02-07-2018 12:32 AM
Free Service & Repair Manuals for Yaris freddist DIY / Maintenance / Service 0 03-29-2017 08:57 AM
5 speed resale value ron3 General Yaris / Vitz Discussion 32 07-12-2013 02:07 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
