Old 05-28-2018, 08:16 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Soft unidentified tinkling noise audible at low speed
I hear a noise at low speed when driving my Yaris with the window open. The best way to describe it is as a tinkling noise. A relative thought it might be a pebble in a hubcap. That's a good description, but I had & have no hubcaps.
It's not loud enough to be heard at higher speeds, especially with the window closed.
I've been hearing it for at least 2 years, and it does not seem to be affecting the vehicle in any way. The Yaris is just a month shy of 10 years old. I bought it new.
QUESTION: Does anybody have any idea what the noise could be and if it is important?
Thanks,
R.
RMcG is offline   Reply With Quote
Old 05-29-2018, 12:40 AM   #2
komichal
My friend experienced something similar, it was coming from rear right wheel. The exhaust muffler was the culprit - while it looked pretty solid outside, there was something loosened inside - it was tinkling and rattling a bit in low RPMs. With higher RPMs the noise was gone - probably the pressure of the fumes did its job.
I am not saying that this is your problem too... just that I have experienced this. :)
Old 05-29-2018, 07:44 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Soft unidentified tinkling noise audible at low speed after wheel change
A month or so ago I installed the summer treads (on circa 1990 Miata steelies w/ a 2 year old powdercoat, leaving the wheel-to-hub/drum interface dry and free of any lube except around the center holes.) and immediately started to hear a "Soft unidentified tinkling noise audible at low speed."
Only other things I did were rattle-can the circa 1990 Tercel steel acorn lugnuts w/ rust converter and squirt Corrosion Block on all seams and fasteners I could see from underneath the Yaris.
No idea of noise source.
Not hearing it now.
Old 05-29-2018, 02:56 PM   #4
RMcG
Thanks Dogsride and komichai,
Any other comments from you or anybody else will be welcomed.
R.
Old 06-05-2018, 05:37 PM   #5
fourbangingfun
fourbangingfun's Avatar
Could be a small stone stuck in one of your rotors. I had the same symptoms in my 07 sedan, even took a video to show the sound I was getting at low speeds. I had to take the wheel off, remove the caliper, and remove the rotor - and the stone fell right out onto the ground. Hope this helps.
https://youtu.be/79KPXKrsZao
fourbangingfun is offline   Reply With Quote
Old 06-06-2018, 12:25 AM   #6
RMcG
Thanks four,
That might be the problem. I'll check.
R.
low, noise, speed, tinkling
LOW RPM @Idle speed = Bad Volt Generation? jp_costarica General Yaris / Vitz Discussion 4 06-14-2012 04:56 PM
Low road noise in Yaris? RedRide General Yaris / Vitz Discussion 32 05-30-2010 08:49 PM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
