#1 |
![]() Drives: 05 echo sedan turbo Join Date: Jun 2018
weight reduction
wondering how light you can get these cars
please share how much you've stripped and the weight of your car now |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Tom from Armstrong Racing will chime in I'm sure but last I checked he was down to 2100lbs with a stripped interior, wire harnesses that are not needed and replaced some of his glass w/ lexan
#3 |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
carbon roof. aftermarket rotors. removing the back seat. lighter wheels. removing the passenger seat. aftermarket suspension. lexan windows. carbon fiber hood. aftermarket brake calipers. removing the AC if you don't need it.
#4 |
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
My racecar is high 1800s fully stripped.
2014 BSpec Divisional Champion |
#5 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I'm at 1951 now with a SEDAN, but I could go lower for sure. I sill have all of the door beams and all hinges/latches, and sound deadening. I have the glass rear window still too.
#6 |
![]() ![]() Drives: 04 3dr HB and 04 5dr RS Join Date: Mar 2018
I'm at 2044lbs with a Full interior minus the back seats and about 1/3 of a tank. I can easily get it to 1999 and keep most of the comfortable stuff in..........amazing!
#7 |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
A lot of people could also stand to lose at least 30-60 lbs.
#8 |
2080lb showroom stock for an echo hatch ;)
#9 |
That must be a dry weight?? and the 5 door has to weigh a bit more than the 3dr no?
| Weight reduction and F/R Balance | eTiMaGo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 04-24-2017 12:00 PM |
| Weight Reductions | scape | General Yaris / Vitz Discussion | 34 | 06-08-2009 02:31 PM |
| Weight Reduction Stage 4 - DIY | SeaYa | General Yaris / Vitz Discussion | 9 | 02-24-2009 09:26 PM |
| Weight Reduction Stage II Pics | Yaris T-Sport | Performance Modifications | 21 | 10-01-2007 01:57 PM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 02:07 PM |
