Old 06-10-2018, 03:25 PM   #1
Runethecursed
Drives: 2009 Yaris S
Bore me to Death! Brake Questions`
Gentlemen and the subsequent FBI agents who call themselves women..
I installed brakes on my car, the Scion XD/Corolla brakes, which is a good thing.
Bad thing, my master decided to take a shiz when in the process of bleeding said brakes
I know we use a dual outlet m10x1 brake fitting
I also know we use a dual outlet on the master cylinder, bore 13/16 and stroke of 1.15
I want a tighter pedal feel
Proposition:
Corolla/Matrix master cylinder with a 7/8 bore.
Stroke: 1.57
also uses two outlets m10x1
would anyone have information on if this master cylinder is a bolt on to the Yaris oem Booster.
I cannot delete the ABS module..
I cannot add proportioning valve..
But I do want a stiffer pedal feel. One thing Ive always appreciated about Honda's is their pedal feel is really remarkable and toight, like a toiger
Runethecursed is offline   Reply With Quote
Old 12-08-2018, 09:51 AM   #2
myfirstyota
3 Yaris and counting..
When I built my supercharged '90 jetta coupe, it got a whole host of upgrades. The 9" solid disks on the front went to the back and the front got the 11.1" corrado rotor with driver edition calipers to match. The master was swapped for one that was 2mm larger iirc. Stainless lines all around.
To put that combo into prospective, when emergency braking on the 401, your attention was more about not getting rear ended then rear ending the guy in front of you. But regular stop and go traffic pedal feel was very stock-like.
I have a 2011xd master sitting on my bench. Want to test the theory myself. But winter has officially arrived and I have no garage. Iirc, the body of the xd master is not the same size as the yaris (shorter and fatter). But I'm thinking it wouldn't be a bad idea to match the master to the brakes I also stole from the 2zr donor car.
Edit: I dug around. Enviri's stolen xd parts thread states the xd brake booster is needed to swap the master
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
