Old 06-20-2018, 11:12 AM   #1
hitmoninfinity
Drives: 07 Yaris Sedan
How to replace aux jack on 2007 sedan
I purchased a new aux port and I'm not sure how to install it. Do I have to take the plastic panel off? Anyone have any pics of an install? I tried searching, but I didn't find any.
hitmoninfinity is offline   Reply With Quote
Old 06-20-2018, 12:38 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Is it in the center of the car or in the dash?
Old 06-20-2018, 02:29 PM   #3
hitmoninfinity
It's in the side pocket on the passenger side.
Old 06-22-2018, 01:12 PM   #4
CrankyOldMan
Hmm. I've only messed with that on a HB. You should be able to remove most of the stuff around it following the "radio replacement" procedure. I.e. pull the plastic parts off in the correct order (side bezels, cluster surround, radio surround, HVAC surround.
Old 06-22-2018, 01:20 PM   #5
hitmoninfinity
As it turns out, it was very simple! No tools required. You can simply reach up behind the plastic and unhook the wire, which is basically a phone cord type plug. Once it's disconnected, push the jack outward toward the back of the car. It slides right out. Then, push the new one in, reach around to the pack and plug in the wire. Done!
2007 yaris sedan aux jack... chief ten bears In Car Entertainment + Electronics (audio / video / alarm) 13 10-26-2016 10:38 AM
2007 Yaris Sedan sroberts Cars for Sale by private party 0 05-20-2015 03:47 PM
Evap canister part number for 2007 yaris sedan baseballfan416 DIY / Maintenance / Service 4 04-25-2015 11:16 PM
