Old 06-23-2018, 01:46 PM   #1
vitz123
Drives: Toyota Vitz
Exclamation Yaris 1.0 2008, engine losing power
So i am suddenly having this issue with my 2008 Model VITZ/Yaris (1.0 Japanese Version), that when i press the gas pedal hard to accelerate fast from idle, the engine RPMs drop and the car doesn't accelerate, the engine sort of dies without cutting out entirely. same is when going up steep slope, the RPM's die down and the car almost stops going uphill. what could be the issue. i have recently changed the engine oil, cleaned the throttle body but no improvement.
The car could get to high speeds accelerating but when you demand sudden acceleration the car just makes a lot of noise but the car doesnt go any faster, but now the issue has gotten worse. the car barely goes to 40mph and with ac it is even harder. Its like there isnt enough power. the engine seemed perfect and powerful until this issue. the car revs high when idle. but when the car is running and the gas is pressed the car just screams a lot but the RPM's dont rise above 3500 and the car doesnt accelerate at all from the current speed. It is only possible to accelerate very slowly on a soft gas pedal.
I recently cleaned the throttle body of the car and i replaced my CAT converter some 10000 miles ago. the engine is fresh. although the model is old. the car has only 60000 miles on the odo meter. i maintain the car carefully.
Kindle suggest the possible issue/s my car might have. Thankyou!
vitz123 is offline   Reply With Quote
Old 06-23-2018, 03:47 PM   #2
Clean the MAF? Next easiest thing to do other than check air filter.
Old 06-23-2018, 07:34 PM   #3
ex-x-fire
Check the fuel pressure.
Old 06-23-2018, 07:44 PM   #4
stykerdk
Yaris Hybrid Limited 2015
Fuel filter would i start with
C-HR 1,8 Hybrid premium 2020
Old 07-08-2018, 01:29 AM   #5
m456an
m456an's Avatar
Drives: Yaris 2005 petrol
Normally iridium spark plugs are good for over 100 000 miles, but worth checking them and to clean the connections tothe ignition coil.
My yaris is 2005 and on 60 000 miles I have ordered comma d-tox that some people say can improve horse power I.e may just be dirty injectors....
m456an is offline   Reply With Quote
acceleration, problem, yaris
oil yaris 2008, 1.0 1krzys Cosmetic Modifications (Exterior/Interior) 1 10-18-2011 08:18 AM
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 12:15 PM
