Old 07-01-2018, 12:01 PM   #1
DevilzMafia
Drives: Toyota Yaris 2007
2007 Yaris Sedan AC clutch holder tool?
My Yaris's AC compressor wheel bearing is out, and I've been trying to remove the 7mm bolt (after leaving it overnight with WD-40), but it just spins the crankshaft. Even after holding the crank pulley down, it still spins!
I also tried giving external power through some wires to the AC clutch actuator, but that isn't working either (the clutch just doesn't engage).
Anyone that's had the same issue been able to fix it somehow?
DevilzMafia is offline   Reply With Quote
2007 Yaris Hatchback A/C Compressor Clutch Removal dinsum DIY / Maintenance / Service 2 05-28-2018 07:38 AM
