Old 07-20-2018, 01:35 PM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
Rough idling and timing Retards
When i turn on the AC the ignition timing retards and the car idles very rough.......is there anything i can do.......im running a POD air filter....checked everything with a obd2 adapter.....all readings are normal except when i turn on the Ac the ignition timing retards to -10......what should i do ? need expert opinions...........and also my coolant temp reaches to 100 degrees
Bony_ahmed is offline   Reply With Quote
Old 08-06-2018, 01:36 PM   #2
m456an
m456an's Avatar
Drives: Yaris 2005 petrol
Pod filters can dirty maf sensor. I would also check lower pressure of air conditioning, it may need regass.
Roads of roads,
Like cars of hope -
Gas and air mix like explosions of exhaustion.
m456an is offline   Reply With Quote
Old 08-08-2018, 07:45 AM   #3
Bony_ahmed
the compressor needed recharging.....fixed it.......thanx
