Old 07-23-2018, 11:54 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
13mm Penguin Hub Spacers Installed
Finally got around to installing the spacers. It was a fairly easy job with the two biggest challenges being disconnecting the wheel speed sensor connectors (was a little worried that they'd break) and separating the hub from the rear suspension beam after the bolts were removed.
The final effect was definitely worth the cost and effort. It makes a big difference! Unfortunately I didn't take any before pics from the same camera angles.
PG Hub spacers group buy Vitz_Q8 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 11-15-2015 02:10 AM
FS Penguin 10mm Rear Hub Spacers (Brand New) skeck Items for Sale by private party 5 03-01-2013 04:24 PM
13mm Penguin Garage Rear Hub Spacers Installed! Jackalope1 Cosmetic Modifications (Exterior/Interior) 20 03-29-2012 12:22 AM
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
