Old 07-30-2018, 03:54 PM   #1
Danger-rouse
Danger-rouse's Avatar
Drives: 2001 VVT-I hatchback
Fluctuating fuel gauge
Hi, I’ve got an ‘01 Yaris, just hit 120k and all of a sudden the fuel gauge is going fluctuating from 3 bars to empty, after only just putting petrol in. Has anyone else had this problem? If I use a fuel cleaner like Redex will this help for the next few cycles?
Any guidance is appreciated.
Danger-rouse is offline   Reply With Quote
Old 07-31-2018, 09:58 AM   #2
have you checked the connector on the fuel tank for corrosion?
Old 07-31-2018, 03:51 PM   #3
Danger-rouse
No not yet. I tried the redex/Carlube this morning and it seems to be working at the moment. MPG has also increased, so fingers crossed ��
Old 08-04-2018, 04:32 PM   #4
nemelek
DWEED
nemelek's Avatar
I had a fuel gauge problem at 80K. Not quite the same problem, however, I used Lucas a few times and it fixed the problem.
Fuel gauge: low fuel indicator eepp DIY / Maintenance / Service 29 10-28-2018 06:07 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Need help ASAP, fuel gauge / shipping car PolarBear DIY / Maintenance / Service 2 09-25-2012 11:06 PM
