Old 08-02-2018, 01:00 AM   #1
ricardo-cr23
Drives: Toyota Yaris 2007 1.5L V4
U0105 Lost communication with fuel injector control module
Hi guys!
I did a complete scan of my car today just to check if it had anything, and it threw the code "U0105 Lost communication with fuel injector control module" in the Power Steering module. The weird thing is that the P/S light is not on, and it was not recently reset. Also the P/S turns on at ignition which means that the light is good.
I have a BlueDriver OBD tool and it said that a common fix is to clean the battery contacts and I did, so I'll wait to see if it throws it again.
Do you have any other suggestions? I saw a post that said that it could be thrown because of constant use of the diag comms port, but I never use it.
Cheers!
ricardo-cr23 is offline   Reply With Quote
Old 08-08-2018, 09:27 PM   #2
ricardo-cr23
Anyone that can help me? :( I cleaned and replaced the battery contacts but the error showed up again.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
