Old 08-08-2018, 05:09 PM   #1
SandJA1
Drives: 2007 2-Dr Hatchback
Question Max/Min/Optimum Coolant temperature numbers for Torque (OBD2)?
Hello, I've searched to no avail for these numbers. I'd like to set up a gauge for the Torque app (obdii). So I just need to know if the numbers I have are the correct numbers and also the number for max temp..
From what I've found online,
- Engine is cold at <=130°F
- Ideal temp is 180°F
- No known maximum temp
What temp does the high temp indicator light go on?
Thank you for any help! I just got the Yaris, so I'm excited to set up all these analysis tools.
SandJA1 is offline   Reply With Quote
Old 08-08-2018, 09:09 PM   #2
SirDigby
Drives: 2007 yaris 3 door
i think the light comes on at 230F...
Old 08-08-2018, 11:32 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
According to service manual; fan-on temp is 93C/199F (which is surprisingly low for a modern car). So the engine's ideal operating range is 180-199F. If you want to confirm, just look at the temp when the fan comes on (make sure HVAC is off).
Old 08-08-2018, 11:38 PM   #4
CoryM
"The engine coolant temperature indicator light turns off when the engine coolant temperature exceeds
55°C (131°F) and illuminates when the temperature decreases to below 45°C (113°F).
The engine coolant temperature warning light flashes when the engine coolant temperature reaches
117°C (242.6°F) and illuminates when the temperature exceeds 120°C (248°F). When the temperature
decreases to 119.5°C (247.1°F) while the warning light is illuminated, the warning light begins to flashing.
In addition, when the temperature decreases to below 116.5°C(241.7°F) the warning light turns off."
coolant temp, max, obd2, obdii, torque
Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? zimso General Yaris / Vitz Discussion 3 10-19-2010 07:17 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
