Old 08-10-2018, 05:02 PM   #1
Yaris709
Drives: 07 yaris
Transmission gasket replacement?
Hey guys got a leak in the transmission base pan gasket, how big of a job is this to do? Is it simple as draining the fluid, take out the bolts and drop the pan or is there more to it?
Yaris709 is offline   Reply With Quote
Old 08-10-2018, 06:55 PM   #2
scylla
Drives: 2015 Yaris L
If you are talking about the automatic trans, yes very easy. I would replace the filter as well while you have it open.
Youtube has some decent tutorials.
scylla is offline   Reply With Quote
Old 08-10-2018, 09:20 PM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes, it is that simple. It was last year that I dropped the pan on my '08 and I added a little RTV sealant to both sides of the gasket before tightening. I also replaced the filter while in there. Go very light on the pan bolt torque. It's something like 70 - 80 in/lbs (~7 ft/lbs).
Here are some pics from during my pan drop...
http://www.yarisworld.com/forums/showthread.php?t=59234
Old 08-11-2018, 10:08 AM   #4
Yaris709
Drives: 07 yaris
Thanks guys! Figured it was pretty straight forward but had to ask to make sure as you never know sometimes. Will get at it in the next couple weeks as it's a very slow leak
Old 08-11-2018, 10:31 AM   #5
06YarisRS
Excellent. It's always a great feeling to have a fresh filter and new, clean ATF coursing through your transmission and your car will appreciate it.
Have you posted any pics of your car?
Old 08-12-2018, 10:28 PM   #6
Yaris709
Drives: 07 yaris
I have some pictures yup! The yaris is treating me well. 296000km and going strong! Just took it on a 2500km road trip last week and the car loved it.
Upstream O2 Sensor replacement and Donut Gasket Flange Repair zerosl DIY / Maintenance / Service 0 03-24-2018 09:56 PM
Front Exhaust Gasket Replacement tmontague DIY / Maintenance / Service 6 03-25-2015 11:00 PM
Replace Transmission Pan Gasket? frankienap DIY / Maintenance / Service 2 11-22-2013 06:09 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
