Old 08-25-2018, 11:17 AM   #1
ron17571
Drives: 2014 Yaris I
key FOB?
I just bought a 2014 Yaris and the keys had a black plastic thing, A fob? that looks to have no button. Does this FOB have any function?
ron17571 is offline   Reply With Quote
Old 08-25-2018, 03:57 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Usually there is a chip in the black thing. The Yaris will read the chip when you insert the key into the ignition to start it.
If you made a duplicate key without a chip and tried to start the car, the starter will crank, but the engine won't start.
A regular key (no chip) will run $5.00-$10.00 a chip key will be around $80-$100 because the chip must work with the car for it to start up correctly.
Old 08-26-2018, 11:13 AM   #3
DarkShadowFox
is it hanging off of it? if it is, its a dummy keyfob for a autostart package they offer.
Old 08-29-2018, 07:55 PM   #4
ron17571
it is separate from the key. The build thread would not work.
Question about adding another key and fob rcvmini DIY / Maintenance / Service 19 10-14-2018 09:17 PM
New remote key fob programming costica DIY / Maintenance / Service 1 04-17-2016 08:02 PM
Replacement key for fob? jorwex General Yaris / Vitz Discussion 2 03-18-2016 06:57 AM
VItz 2010 Push Start Fob key Programming (Duplicate Smart Key). ahsanraza Performance Modifications 1 02-03-2016 06:29 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
