Old 08-25-2018, 06:16 PM   #1
Zessira
Drives: 2008 Toyota Yaris
2008 Yaris Serpentine Belt Gone
I was driving my Yaris when there was a loud bang as I accelerated. The charging system light came on, followed by the low engine coolant indicator light. The check engine light came on as well. I was 15 minutes from home, so I chanced it and drove home. It drove fine and I made it home. The check engine light DTC: P0117-Engine Coolant Temperature Circuit Low. Under the hood, the serpentine belt was gone. My question is, can I just replace the belt, or does the timing need to be checked?
Zessira is offline   Reply With Quote
Old 08-25-2018, 07:25 PM   #2
dogsridewith
Drives: 2007 2-door hatchback
Serpentine belt isn't involved w/ timing...but 15 minutes w/ no water pump risks warped block/head and ?
Did it smell funny when driving w/o belt? Any spray marks on the bottom of the hood or anywhere else? What are coolant levels in the radiator and coolant reservoir?
I'd do an oil change. Inspect oil and open the filter.
Old 08-25-2018, 08:14 PM   #3
SirDigby
Drives: 2007 yaris 3 door
yes. serpt belt runs waterpump. it is bad to drive without it.
Old 08-27-2018, 12:20 AM   #4
B.B._07
Drives: 07 5dr
Just replace the belt, check the coolant level and keep driving. If the head gasket is blown it's already after the fact. A blown head gasket will present itself with the usual symptoms of loosing coolant, white exhaust smoke, and (if it's bad enough) overheating.
Old 08-28-2018, 10:42 PM   #5
jra
Drives: 2015 yaris L
About all you can do is replace the belt and see what you have, You should check all the pulleys to see if a bearing froze up causing the belt to break.
jra is offline   Reply With Quote
Old 08-29-2018, 06:45 AM   #6
sunsanvil
Drives: 2018 LE 5DR A4
Our 07 belt spontaneously snapped this summer. It was a hot day so in just a minute or so we got the over-temp light and immediately pulled over. Had it towed to a service center.
Seems that the 10 year mark would be a good time to change these, even if they look ok.
sunsanvil is offline   Reply With Quote
2008 yaris, broke, p0117, serpentine belt
Oil change shop says alternator belt is cracked RMcG DIY / Maintenance / Service 19 05-02-2018 07:38 AM
2008 Toyota Yaris making strange noise kylievolz DIY / Maintenance / Service 1 12-05-2017 06:14 PM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
