Old 09-05-2018, 05:13 PM   #1
Jedurso
Drives: 2010
Strong vibration on highway..... help
Hi all. 2010 yaris. 105 thousand miles. 500 miles highway weekly.
So, I have a strong vibration and pulling to the right. Most notiable on highway. Took for an alignment, didn't help. Took back 3 days later, realignment, didn't help. Say it's suspension.... okay. Tire rods are fine, control arms are fine. Where am I looking????? I have new spark plugs, coil packs, fuel injectors, and belt. Also took off and cleaned my throttle body and rear breaks are a month old. I do need tires.... can it be that simple?. Please help, this is my only vehicle and it has to last.
Jedurso is offline   Reply With Quote
Old 09-05-2018, 07:25 PM   #2
ex-x-fire
The tires could be causing a pull, try crossing the fronts. If it pulls the other way then its the tires, if not then its an alignment issue. Did you get a alignment print out?
The vibration could be tires or an axle shaft. Get the front up in the air on jack stands, block rear tires, e brake on. Have some one get inside it and put it in drive, have them load it by applying the brakes a little. This may make the vibration show itself. If it is vibrating, look at the engine/trans, is it moving side to side a little? If so then I'd suspect an axle. Look at the tires, do they look round, even a small bulge will cause issues.
Old 09-05-2018, 08:54 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
check your shock/struts. It could be as simple as your tires or wheels, yes...CT roads suck! (unless you live on rt 8, minus random debris)
Strong vibration on highway..... help Jedurso Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 09-07-2018 06:11 PM
Excessive vibration over 60mph. Suspension related? Aclosefriend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-29-2016 06:06 PM
Pulsating Vibration dbudworth General Yaris / Vitz Discussion 5 03-28-2011 04:06 PM
Strong vibration when accelerating... why peposhi General Yaris / Vitz Discussion 8 02-25-2010 08:29 PM
Vibration or shake at highway speed? evan DIY / Maintenance / Service 10 11-10-2008 09:23 AM
