Old 09-20-2018, 05:21 PM   #1
EGGBEATER
Drives: 08 Yaris HB
Headlight woes.
Hey there, having some headlight issues.
Tuesday my passenger side headlight went out, so of course I grab a new bulb and toss it in, and it doesn't light up all the way. Dim, and not coming all the way on. So, I figure maybe I got a bum bulb and get another, same issue. Started googling around, checked my underhood 10A fuses, all were fine. Wiggled the connector around, no change. Used a multi on the connector, and was getting about 5 volts and then it started dropping down on the green wire, the black and blue wires were like .004 volts I think. Checked it with car off, and car in accessory.
Thought maybe I had a bad ground, only one I can find that looks like it may go to it is a small wire (same size as the HL connector wires) that is white, and connects to the frame for the radiator on the drivers side. It looked fine, and the drivers side bulb has no issues so I didn't mess with it.
Any help would be appreciated. It worked fine before, now kaput.
Car Info:
2008 Toyota Yaris Hatch
All stock.
EGGBEATER is offline   Reply With Quote
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Replacing headlight bulbs in under 5 minutes without removing the bumper 07liftback DIY / Maintenance / Service 0 01-23-2015 11:11 AM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
