Old 09-29-2018, 04:25 PM   #1
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
Will a C60 Transmission........
bolt up to a 1NZ-FE in a 2004 Echo?
and is the C60 a similar shift cable setup if it will bolt up?
Thanks for any help.
Ronnie V is offline   Reply With Quote
Old 09-29-2018, 05:19 PM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
No, there are many modifications that need to happen to get a c60 to fit. There are several posts about it already
Old 10-01-2018, 05:30 PM   #3
Ronnie V
Thanks, your reply was everything I needed to know.
Old 10-05-2018, 09:42 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You can look at BluevitzRS's C160 swap to see what's involved in the 1st gen Yaris/Echo. It's not a bolt-in mod since it requires notching the frame rail. Armstrong just put a C60 in his 2nd gen Yaris sedan and required the same modification.
That said, it may be possible to use an EC6X style from a recent gen MT Corolla, but nobody has done any research into mounts, brackets, cables, wiring etc. and adapting the throw-out bearing from lever to cylinder style. Don't be discouraged though, there are plenty of people here that would be willing to help point you in the right direction to start the research yourself and you'd get mad props from the community for pioneering the swap.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Transmission heating up ? David C DIY / Maintenance / Service 9 08-04-2016 01:25 PM
Transmission oil? jamesxl DIY / Maintenance / Service 3 04-11-2016 10:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
