Old 10-07-2018, 03:34 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Corolla/xD Big Brake kit install problems
I bought the BBK that Brushforhire had on his Yaris a year or more ago. Finally getting around to installing it since the slide pin holes on my stock brackets were completely trashed and beyond saving. Hooray for road salt!
Everything bolts up just fine, except I had to trim the ends of the shields to make room for the bracket. Nothing a quick zip from a cutoff wheel can't handle. The problem is that once the bracket gets snugged up, the rotor won't turn anymore.
I put two nuts on the studs to make sure that the rotor was in the right position and centered. No luck there either.
I know there's only a few of us who have done this swap, so I'm hoping one of them still frequents the forums and sees this.
Old 10-07-2018, 06:50 PM   #2
CrankyOldMan
Disregard. I hadn't seated the hub completely after replacing the wheel bearing. Put the wheel back on, set it on the ground, gave it a few full turns until it seated properly.
Now if I could just get the damned brake line fitting loose from the hard line...
Old 10-08-2018, 12:18 AM   #3
Runethecursed
Drives: 2009 Yaris S
Originally Posted by CrankyOldMan View Post
road salt!
Runethecursed is offline   Reply With Quote
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
Big Brake kits for Yaris 5 door mojoyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-23-2007 12:30 AM
big brake kit yrsdrgn Performance Modifications 17 02-20-2007 11:05 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 12:04 AM
