Old 10-25-2018, 10:52 PM   #1
Mo_Macaroni
Drives: 2007 yaris
Question Accidentally put transmission fluid in engine ?!?!
M. 2007 yaris
I was meaning to drain and refill the transmission fluid, instead I drained it and put 3 quarts of transmission fluid into the engine. Then i drove 22 miles to and from work with no transmission fluid and 3.9qt motor oil, 3qt atf mixed in my engine. When I got home I knew the car was driving weird so i checked it then after loosing my sh!+ I draine oil/atf and added all the correct motor oil and atf. Also changed the motor oil filter. Is there anything else I should do or look out for.
Mo_Macaroni is offline   Reply With Quote
Automatic Transmission Fluid - Drain and Fill vinny121 DIY / Maintenance / Service 5 04-07-2022 06:48 AM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
DIY ATF fluid flush - fluid return lines tmontague DIY / Maintenance / Service 2 10-15-2018 02:46 PM
Manual Transmission Fluid Woes tmontague Performance Modifications 4 10-08-2018 09:12 AM
Shipping a Engine & Transmission... Astroman Off-topic / Other Cars / Everything else Discussions 9 07-07-2007 11:45 AM
