Old 10-28-2018, 01:47 PM   #1
Hoodyjay
Drives: 2007 Toyota Yaris Sedan BASE
Prongs on block heater
Previous owner obviously did not care about the three prongs you would plug into an outlet to keep the engine/battery warm. They drove with it out, scrapping against the ground. The prongs are definetly some for. Is there a way I can cut the end off, and put in new prongs?
Hoodyjay is offline   Reply With Quote
Old 10-28-2018, 01:51 PM   #2
You can pr0bably buy a generic Male end from a hardware store and splice it in to the existing wiring
Old 10-28-2018, 03:04 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
I've never seen a plug with replaceable prongs, but some plugs are made such that one possibly could replace the prongs.
Engine block heater HELP! Meeksworth Third Gen Yaris General Discussion 7 01-30-2026 03:18 PM
Block Heater location alar DIY / Maintenance / Service 4 10-23-2012 06:45 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Yikes, thats an expensive block heater HDS DIY / Maintenance / Service 2 12-17-2009 07:30 AM
