#1 |
Radical Dreamer
Drives: off of T9 Join Date: Jun 2017
FS SoCal: Cusco, G's, SR Factory, TRD
What's up Yarisworld,
I sold my Yaris when I relocated from SoCal to Michigan. These are the parts that I took off of my 2017, so they should fit 2012-2017. Parts should fit 2007 - 2011, but it's up to you to verify. *Note: Parts are with a friend in Southern California, Local Pick Up Preferred. SOLD SR Factory Bloodsports Rear Torsion Beam Collars. Made of Delrin. Minimizes rear torsion beam movement, it will cause more NVH. Because Racecar. $75 MT Pedal Covers. The brake and clutch covers are from a genuine G's Vitz. They have a different shape than IS300 pedal covers. The gas pedal cover is off of a MK2 MR2 made by SRP Pedals and is installed with self tapping screws right into the factory pedal, yes you will also get the factory pedal. Not only do these covers look great, they also feel great (no more squishy rubber). I found it easier to heel toe with the extended gas pedal. Make your driving experience more engaging! $100 TRD SS Lines; Brake and Clutch lines. These are for 4 Wheel Disc vehicles; i.e. Vitz G's, RS, and Yaris SE. Included are 6 brake lines (2 fronts, 2 middle, 2 rear) and 1 clutch line. You will need new copper crush washers (8 total I believe, one for each side of the banjo, I found some on Amazon) when installing, the factory banjo style washers won't work due to TRD's design. These will probably fit drum equipped vehicles minus the 2 rear lines (hardline to wheel cylinder vs flex line to caliper). One of the best mods I've done, threshold brake with confidence. $150 Cusco Coilover $500 Pick Up Only. http://www.yarisworld.com/forums/showthread.php?t=60873 If interested, shoot me a PM, and I'll get back to you as soon as I can. Thanks!
If you lack driver skill, add horsepower. Last edited by deng; 11-22-2018 at 01:08 PM. |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
interested in the collars
could you ship to 13669 (New York) ? Will
https://www.instagram.com/3cyltrbo/ |
| FS: SoCal TRD Rear Sway Bar | deng | Items for Sale by private party | 2 | 10-01-2017 06:00 PM |
| Vitzoomph TRD turbo M | TTM | Photo-Video-Media Gallery | 19 | 02-01-2017 12:43 PM |
| FS: TRD Axle Back exhaust socal | evil03 | Items for Sale by private party | 2 | 06-17-2014 10:45 PM |
| TRD Exhaust and TRD Header questions | Liquidus Ocelot | Performance Modifications | 8 | 02-23-2014 02:58 PM |
| TRD OR Eibach...i'm confused... | hoahmaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 11-07-2008 08:25 PM |
