#1 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I've had plans to have a RyWire style harness for a long time, but no one wants to build one for any of us without a 2JZ...
My solution = build one myself. I had a spare 2ZR harness laying around that came with my engine from the junkyard, but it was damaged in the accident. Step 1 - I stripped it down, labeled it all, and formed a plan of how to route it cleaner.
Data doesn't lie
Step 2
The routing plan.
Now, of course, I will need to have sub-sections branching out from the main loom. I'll try to keep it super clean along the way.
#3 |
Data doesn't lie
Step 3
Now thanks to Cranky I have plenty of this recycled braided loom, so I'll start doing the loom in sections where there are groups of connections. You can also see the mil-spec circular connector in the center, this is for a quick twist disconnect of the whole drivetrain from the car. (I'll need another plan for the starter and alternator cables).
I started with the coils, heat-shrink the end shut where cylinder 1 is, measure the distance between each plug and cut slots in the loom to feed the wires through. Tape that up with the yellow electrical tape. Next was the injectors, followed by the crank sensor and VVT OCV's.
#4 |
Data doesn't lie
Step 4
Reserved for harness - alternator, knock sensor, throttle body
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-06-2018 at 11:53 PM. |
#5 |
Data doesn't lie
Step 5
reserved for harness - cam sensors, A/F sensor, coolant temp & MAF sensor
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-07-2018 at 12:15 AM. |
#6 |
Data doesn't lie
Step 6
Reserved for harness - HES connector location and chassis side routing
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-07-2018 at 12:11 AM. |
#7 |
Data doesn't lie
Step 7
reserved for harness - assemble connector
#8 |
Data doesn't lie
Step 8
Reserved for harness - starter cable
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-07-2018 at 12:12 AM. |
#9 |
Data doesn't lie
Step 9
reserved for harness - alternator cable
#10 |
Data doesn't lie
Step 10
reserved for harness - testing
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-07-2018 at 12:13 AM. |
#11 |
![]() Drives: Toyota Echo Join Date: Oct 2016
Impressive stuff. Will be following this
#12 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
I swear I'm not a hoarder, if only because I sometimes get rid of stuff. =)
#13 |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
This is awesome. Are you using a stock ecu or standalone?
#14 |
Data doesn't lie
Stock ECM so anyone can use it. And with the HES connector the harness is expandable to be used with any standalone or piggyback controller.
#15 |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Sub'd! Looking forward to seeing this come together. Thanks for the great work as always, Tom!
-- Adam |
| Tags |
| wire tuck |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Engine Delayed Start - Toyota 1NZ-FE 1.5L | SL Runner | General Yaris / Vitz Discussion | 9 | 07-23-2011 03:13 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
