Old 11-11-2018, 04:09 PM   #1
ACKING_QC
Drives: 2018 VW TSi Stage1
Exclamation (URGENT) Yaris Speed sensor with vs without ABS ???
I'll explain, I tried selling my digital cluster to a fellow enthusiast, BUT his car is a 2007 without ABS ... the cluster worked EXCEPT that the speed unit (km/h) stayed to ZERO all the time
in my car, a 2008 LE WITH ABS everything works fine, I'd like to know if the sensors are different because this guy really wants the instrument cluster...
ACKING_QC is offline   Reply With Quote
Old 11-11-2018, 04:21 PM   #2
DarkShadowFox
[QUOTE=ACKING_QC;818842]I'll explain, I tried selling my digital cluster to a fellow enthusiast, BUT his car is a 2007 without ABS ... the cluster worked EXCEPT that the speed unit (km/h) stayed to ZERO all the time
in my car, a 2008 LE WITH ABS everything works fine, I'd like to know if the sensors are different because this guy really wants the instrument cluster...[/QUOTE
i
f he doesnt have ABS then you need a non ABS cluster otherwise your ABS light will be on and the cluster will fail to function.
all yarises should have ABS, i have yet to find a yaris that DOESNT have ABS.
Old 11-11-2018, 05:09 PM   #3
ACKING_QC
[QUOTE=DarkShadowFox;818843]
i
2007 Base model 2 door that the guy brought to my door doesnt seem to have ABS.. OR if what you say is true and ALL YARIS HAVE ABS... then it's only a matter of a FUSE to change (if I'm...well.. if the guy is lucky... otherwise entire new system...)
Old 11-11-2018, 08:30 PM   #4
My 2006 LE is not equipped with ABS. Statement that ALL Yaris have ABS is false.
Sent from my EML-L09 using Tapatalk
Old 11-12-2018, 12:59 PM   #5
ACKING_QC
Knew I wasnt crazy
My question is, is there a way to make an abs speedometer on non ABS car ?
Must be at least one way...
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Wanted: 2007-08 Yaris S instrument cluster (w/tach w/o ABS) for 2007 Yaris hatchback AndyW Willing to Buy by private party 6 12-07-2014 08:53 PM
Adding ABS to a Yaris tadc Performance Modifications 1 02-14-2010 03:56 PM
