Old 11-23-2018, 06:10 PM   #1
Saint
Saint
Drives: 2011 toyota yaris
rough ride
Hi everyone ,
I have a 2011 yaris hatch which I bought from a lady with only 18k on the clock about a year back. I now have 30k on it. My concern is the rough ride. She used to use the car in Boston and did not seem to have driven it much. I drive like 40 miles a day and the rough ride is getting me down. The suspension seems to be very hard, as I feel each and every small pot hole . I went to the Toyota dealer and tried the new yaris just to compare and found that the suspension feels much tighter and with more cushioning. I showed the car to the dealer and they say everything is fine, but then if it is fine why does my car ride so rough? They have no answer except to say leave it with us and we will check and let you know. I somehow am not comfortable with that and so did not leave it with them. You think the shocks might be bad or something like that. I went under and checked to see if I can find anything unusual, but all the rubber bushings seem to be good.
I will give you an example of the roughness. When you drive on the little yellow dots in the center of the road it feels like there is no suspension action at all and I can feel the thuds.
Any advise on this ??
Saint is offline   Reply With Quote
Old 11-23-2018, 06:28 PM   #2
Replace the shocks/struts if that is what you think the issue is.
Unless they are leaking, there isn't really anyway to know oif they are bad except for feeling how the ride is
Bad shocks will typically cause bouncing since the springs are uncontrolled
Old 11-23-2018, 06:30 PM   #3
thetut
Drives: 2007 4dr sedan
What's your tire pressure?
thetut is offline   Reply With Quote
Old 11-23-2018, 07:33 PM   #4
Saint
Saint
34 front and 32 at the back.
Old 11-24-2018, 04:23 PM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
could be the brand/model of tires. My previous Falken ZE914 Ecorun were really noisy and bumpy. Switched to Yokohama Bluearth ES32 and they are much more quiet and comfortable.
Fluxtasy is offline   Reply With Quote
Engine Control Module Code and Rough Idle rks171 DIY / Maintenance / Service 4 05-13-2015 10:47 PM
Need advice/ help for rough idle lilj4321 DIY / Maintenance / Service 2 08-28-2012 02:39 PM
new shocks/tires for a more comfortable ride? jbob10 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 05-10-2011 07:34 PM
"Bouncy" Ride After DF210s? MadMax Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 05-12-2009 10:04 AM
rough surface... abdallah380 Wash, Wax, Detailing, Exterior Repairs 6 02-16-2009 01:09 PM
