Old 11-25-2018, 08:28 PM   #1
nvfool
Drives: 2012 sedan
Both VSC and ABS lights on!
Both lights stay on. There are no codes on the OBDII. How do I troubleshoot this?
nvfool is offline   Reply With Quote
Old 11-26-2018, 05:56 AM   #2
What are you using to read the codes?
Sent from my CLT-L04 using Tapatalk
Old 11-26-2018, 06:17 AM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
See link below. This is probably your solution. Driver's side rear seems to fail most commonly. OBD2 cannot access brake related data, afaik.
http://www.yarisworld.com/forums/sho...&highlight=abs
Both VSC and ABS lights on nvfool Third Gen Yaris General Discussion 6 12-04-2018 06:19 PM
VSC and ABS lights on. hannibal Third Gen Yaris General Discussion 3 12-06-2017 12:40 PM
what winter tires do you use ? henry33 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 12-09-2010 10:31 PM
2010 in Canada : ABS and VSC optional??? pierdeux New YARIS Purchase Forum 4 03-28-2010 03:23 PM
Invasive creature or standard feature? Small cars and VSC, ABS, and traction control Thirty-Nine General Yaris / Vitz Discussion 19 08-10-2009 11:29 AM
