#1 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Rear brake shoe advice needed
I'm looking for advice on what rear brake shoe compound I should run for next track season. I have carbotech xp10's up front and love them and I'm a big fan of carbotech's customer support. I have been using stock rear shoes and they have held up pretty good but are now almost completely worn.
Carbotech recommended u run xp8's in the rear for the track with my set up of 80tw tires and the weight of my car. Problem is, these are one off's to make and cost $240 a pair regardless of what compound I go with. My question to those who track and even autox their cars is, did you notice a large difference going with a track pad in the rear over the oem compound? I'm trying to figure out if it is worth the $ to go with track shoes or not. I dont know is Jason still goes on this forum or not but I'm curious as to what he ran in the rear. I am far from a pro driver but I do 45 min session at a time and I brake super late and drive the crap out of the car at the track. To put it in perspective hawk hps pads lasted half a lap on my first hot lap and they never recovered Thanks
![]() ![]() Drives: 2008 HB Join Date: Dec 2012
I'd call the guys at Porterfield, they are the one that helped Jason.
https://www.porterfield-brakes.com/ |
#3 |
Thanks, I'll contact them
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
I know some of the B-Spec guys (they have ABS we don't in H Prod) found that too much rear brake put the car in ice-mode. Still have the original rear shoes on the car after four seasons. HPS is a street pad, not a good choice for the front for anything other than autocross. We have Porterfield cut out a Hawk DTC-60 for the front of the Yaris.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#5 |
Track or no track, I've never heard a case for anything other than OE.
Sent from my EML-L09 using Tapatalk
#6 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
#7 | |
I agree with your on the HPS pads, they were what u had when I started tracking the car but as I started to work on brake zones and threshold braking they fell apart very fast. Now I just use them for dding and they are fine for that. I know what you mean about "ice mode". TMP has a chicane right before a 90 degree corner and if I apply the brakes a few feet too early I do so during a bump and I completely blow the corner - the abs will kick in on all 4 wheel for the next 4 seconds making my brakes useless.
| Advice on wheel spacers and sway bars needed! | Lars | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-05-2013 11:28 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
